WSGL775 Posted January 7 Report Posted January 7 I'm new to understanding radio frequencies, specifically programming certain frequencies into the radio. I understand UHF and VHF and the frequency ranges that encompasses each. However, where I get confused is this specifically: GMRS 1 - 462.562MHz GMRS 2 - 462.587MHz In between those two frequencies, is there room to program a frequency such as 462.750? I don't understand the theory behind why there is a large gap between frequencies. Could someone elaborate on this so I'll understand? I just got my license and don't want to make foolish mistakes and lose it! Many Thanks in advance! Quote
WRUU653 Posted January 8 Report Posted January 8 GMRS-16- 462.575 sits there already. WSGL775 and SteveShannon 1 1 Quote
SteveShannon Posted January 8 Report Posted January 8 12 minutes ago, WSGL775 said: I'm new to understanding radio frequencies, specifically programming certain frequencies into the radio. I understand UHF and VHF and the frequency ranges that encompasses each. However, where I get confused is this specifically: GMRS 1 - 462.562MHz GMRS 2 - 462.587MHz In between those two frequencies, is there room to program a frequency such as 462.750? I don't understand the theory behind why there is a large gap between frequencies. Could someone elaborate on this so I'll understand? I just got my license and don't want to make foolish mistakes and lose it! Many Thanks in advance! Hi John, For GMRS and FRS, the FCC has designated 22 specific frequencies for our simplex use and 8 more for transmitting to the repeater. The channels are interlaced. So tuning to an “in-between” frequency might be interfering with other services or other channels. You’ll definitely want to read the regulations to see what frequencies we are allowed and the power and bandwidth: § 95.1763 GMRS channels. The GMRS is allotted 30 channels—16 main channels and 14 interstitial channels. GMRS stations may transmit on any of the channels as indicated below. (a) 462 MHz main channels. Only mobile, hand-held portable, repeater, base and fixed stations may transmit on these 8 channels. The channel center frequencies are: 462.5500, 462.5750, 462.6000, 462.6250, 462.6500, 462.6750, 462.7000, and 462.7250 MHz. (b) 462 MHz interstitial channels. Only mobile, hand-held portable and base stations may transmit on these 7 channels. The channel center frequencies are: 462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, and 462.7125 MHz. (c) 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz. (d) 467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz. WRUE951, WRUU653, TrikeRadio and 3 others 5 1 Quote
UncleYoda Posted January 8 Report Posted January 8 On GMRS certified radios the channels [1-30] are already programmed. Channels 1-14 should have 4 digits after the decimal like 462.5625. These all end in 5 - they're 12.5KHz above and below the frequencies for channels 15-30. If you do a search you should be able to find a chart to help you visualize the relationship. H8SPVMT, AndyOnTheRadio, WSGL775 and 3 others 4 2 Quote
WSGL775 Posted January 8 Author Report Posted January 8 Thanks for the explanation! I wasn't sure if you could just use in between frequencies. Now I understand that it could disrupt others services that share the frequencies. Don't want to do that on any frequency! You know, I did read § 95.1763 GMRS channels and it just went right over my head since the radio already had them programmed in there. I'll admit, I was in a hurry and not paying attention. But again, I appreciate the responses! SteveShannon and WRUU653 2 Quote
WRYZ926 Posted January 8 Report Posted January 8 Here is a full list of all the FRS/GMRS channels. https://www.buytwowayradios.com/blog/2022/11/list-of-gmrs-frequencies-and-channels.html?srsltid=AfmBOopMy04seYsWSiiA4DFSusU7BoworzqVnVNJg83cZ5PuwO9Wl5V7 WSGL775, WRUU653 and SteveShannon 3 Quote
AdmiralCochrane Posted January 8 Report Posted January 8 WRUU653, SteveShannon, WSGL775 and 4 others 4 3 Quote
H8SPVMT Posted January 9 Report Posted January 9 (edited) My ole eyes and brain just did not compute this knowledge until, NOW! Thanks to all that asked and to those that answered! I kept seeing the words "Mobile GMRS" and thinking my MXT-400 qualified for that. But then comes along... "467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz. So now I realize why I don't have those channels in my radio! We had this exact problem on the trails (Trail Guild wanted to use CH 10.....) now it sinks in after studying this, again Thank you all~! Edited January 9 by H8SPVMT Add to the comments WRYZ926, WSGL775, WRTC928 and 2 others 5 Quote
WRTC928 Posted January 9 Report Posted January 9 2 hours ago, H8SPVMT said: "467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. That's why I have those channels set to not transmit on my mobile units. They're there, and if I have a good enough reason, I can fairly quickly turn the transmit feature back on. Having them in the radio means I can listen and even scan them if I want. So far, I haven't felt the need to do that, but it's an option. WRUU653, WSGL775 and SteveShannon 2 1 Quote
WRYS709 Posted January 9 Report Posted January 9 6 hours ago, WRTC928 said: That's why I have those channels set to not transmit on my mobile units. They're there, and if I have a good enough reason, I can fairly quickly turn the transmit feature back on. Having them in the radio means I can listen and even scan them if I want. So far, I haven't felt the need to do that, but it's an option. Which mobile do you use? Quote
MarkInTampa Posted January 9 Report Posted January 9 On 1/7/2025 at 8:31 PM, AdmiralCochrane said: I'm stealing this chart. It's the first time I've seen the frequencies laid out this way, pretty cool. WSGL775 1 Quote
nokones Posted January 9 Report Posted January 9 On 1/7/2025 at 6:31 PM, AdmiralCochrane said: 99 This chart is inaccurate and is mostly confusing and contrary to the rules in Parts 95.567 and 95.1767 in respect to RF output power levels for both the FRS and GMRS radio services. The rules state that Channels 1-7 are regulated to 2 watts ERP for non-licensed FRS service and 5 watts ERP for licensed GMRS service. The left chart indicates channels 1-7 for both FRS & GMRS are regulated to a .5 watt and that is incorrect. The right chart indicates that Channels 8-14 are regulated to .5 watt ERP for FRS and that is correct, and 5 watts for GMRS and that is incorrect, all transmitter transmitting on these channels are regulated to a .5 watt ERP, regardless of the two radio services. The left chart indicates that channels 15-22 are regulated to 2 watts ERP and that is correct. Both charts indicates that the 462 (462.550, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, and 462.725) and 467 (467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700, and 467.725) Main Channels are regulated to 50 watts and that is correct, except for the 467 main channels, they are regulated to 15 watts for fixed class station operations. The 50-watt output is not limited to the measurement of antenna ERP for the 462 & 467 main channels. The 50-watt output limit is the measurement of power out of the transmitter before the antenna and there is no limit of the ERP of the antenna. SteveShannon, WSGL775, WRUE951 and 3 others 5 1 Quote
Lscott Posted January 9 Report Posted January 9 FRS-GMRS Channels Layout.pdf SteveShannon, WRXB215, WRUU653 and 1 other 4 Quote
MarkInTampa Posted January 9 Report Posted January 9 6 hours ago, nokones said: This chart is inaccurate and is mostly confusing and contrary to the rules in Parts 95.567 and 95.1767 in respect to RF output power levels for both the FRS and GMRS radio services. The rules state that Channels 1-7 are regulated to 2 watts ERP for non-licensed FRS service and 5 watts ERP for licensed GMRS service. The left chart indicates channels 1-7 for both FRS & GMRS are regulated to a .5 watt and that is incorrect. The right chart indicates that Channels 8-14 are regulated to .5 watt ERP for FRS and that is correct, and 5 watts for GMRS and that is incorrect, all transmitter transmitting on these channels are regulated to a .5 watt ERP, regardless of the two radio services. The left chart indicates that channels 15-22 are regulated to 2 watts ERP and that is correct. Both charts indicates that the 462 (462.550, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, and 462.725) and 467 (467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700, and 467.725) Main Channels are regulated to 50 watts and that is correct, except for the 467 main channels, they are regulated to 15 watts for fixed class station operations. The 50-watt output is not limited to the measurement of antenna ERP for the 462 & 467 main channels. The 50-watt output limit is the measurement of power out of the transmitter before the antenna and there is no limit of the ERP of the antenna. I like the chart for how is visually displays the channels and frequencies, didn't even look (or care) about the power limit thing. I've got a similar chart for shipboard communications in kind of the same format, it's just the first one I've seen for GMRS. WRUU653, Lscott, WSGL775 and 1 other 4 Quote
WSGL775 Posted January 9 Author Report Posted January 9 What a wealth of information this has become for me in understanding how things work and what is authorized in accordance § 95.1763 GMRS channels. Sometimes you have to slow down to speed up, if that makes any sense to you. Thank you, all of you for this help! Lscott, WRUU653 and SteveShannon 3 Quote
WRTC928 Posted January 10 Report Posted January 10 On 1/9/2025 at 4:08 AM, WRYS709 said: Which mobile do you use? I had an Anysecu WP9900 until it mysteriously stopped transmitting. After I cursed and complained about it and posted a bad review, I found out I had a loose antenna connection which was intermittently shorting. I probably burned out the finals. Moral of the story: Check your SWR frequently. I may get another one someday because I really like the form factor. Currently, I'm using a TYT TH-9800 quad-band (10m, 6m, 2m, and 70cm) radio. It's pretty cool because it's essentially two radios in one. The left one can operate and scan on everything in those bands and monitor AM traffic on the CB band. I think it can transmit FM CB, but I haven't tried it because I would need an entirely different antenna. My current antenna is 6m, 2m, and 70cm. The right portion of the radio can only operate and scan on 2m and 70cm. I have programmed in the GMRS channels, GMRS repeater, and the Ham repeaters in my area, the VHF and UHF "calling" frequencies, as well as the CB frequencies. Typically, I'll set the left side to my "home" repeater and the right side to scan 2m and 70cm, which is where any action typically is. We've had significant snow here the past 2 days, so when I had to go out, I set the left side to scan so it ran through the CB frequencies as well. Kind of a neat feature. I rarely listen to CB because it's a s***show, but it's still the best way to get information about road conditions. Quote
WRYS709 Posted January 10 Report Posted January 10 Now if there was only a quad band radio that supports SSB as well as FM (and hence, even digital!) Quote
WRYZ926 Posted January 11 Report Posted January 11 5 hours ago, WRYS709 said: Now if there was only a quad band radio that supports SSB as well as FM (and hence, even digital!) That would take an all band all mode radio AKA shack in the box such as the Icom IC-7100 or Yaesu FT-991. Those two radios are capable of FM, AM, and SSB on all of the HF bands, 2m, 6m, and 70cm. They will also do CW and digital modes. I wish Icom, Yaesu, or one of the Chinese manufacturers would make a 2m/70cm mobile radio capable of AM and single side band. As it is you have to look on the used market for a mobile radio with AM and SSD capabilities. Though none of that is applicable to GMRS since it is FM only. Quote
WRYS709 Posted January 11 Report Posted January 11 3 hours ago, WRYZ926 said: That would take an all band all mode radio AKA shack in the box such as the Icom IC-7100 or Yaesu FT-991. Those two radios are capable of FM, AM, and SSB on all of the HF bands, 2m, 6m, and 70cm. They will also do CW and digital modes. I wish Icom, Yaesu, or one of the Chinese manufacturers would make a 2m/70cm mobile radio capable of AM and single side band. As it is you have to look on the used market for a mobile radio with AM and SSD capabilities. Though none of that is applicable to GMRS since it is FM only. I have my Yaesu FT-857d, so I am well aware of the shack in the box, but none of the truly portable ones are manufactured anymore. So there is nothing I can recommend. But I have my Radioddity DB20-G and I purchased a Quansheng UV-K5(8) and flashed the IJV3 Firmware and now for $20 I have a 2 meter/440 DSB HT that is compatible with SSB. I made a 65 mile contact with my legacy AEA 5/8 telescoping antenna on 2 meters SSB. AdmiralCochrane 1 Quote
WRYZ926 Posted January 11 Report Posted January 11 9 hours ago, WRYS709 said: I have my Yaesu FT-857d, so I am well aware of the shack in the box, but none of the truly portable ones are manufactured anymore. So there is nothing I can recommend. But I have my Radioddity DB20-G and I purchased a Quansheng UV-K5(8) and flashed the IJV3 Firmware and now for $20 I have a 2 meter/440 DSB HT that is compatible with SSB. I made a 65 mile contact with my legacy AEA 5/8 telescoping antenna on 2 meters SSB. It really is a shame that no one makes a mobile radio with those features anymore. I have a Quansheng UV-K5 (8) that I installed IJV3 on but I haven't tried the DSB mode yet. I doubt that I will add the extra board for HF though. On subject. As the photos and graphs show, channels 8-14 are in-between the repeater input channels and that is why 8-14 are limited to 0.5 watts. Though my testing has shown that transmitting on channels 8-14 at 4 watts did not cause any issues when I had my base radio on a repeater channel and also on simplex listening on the repeater input frequency. I tested with an unlocked HT set to both narrow and wide band and high power which was 4 watts. I would not suggest doing that with an unlocked radio set at 20 watts or higher. And we have to stick with the designated channels for GMRS since their are other users near the same frequencies that we do not want to interfere with. Quote
WRYS709 Posted January 11 Report Posted January 11 Retry your experiment with Input Tones on these channels if you have time, and report bach. Quote
WRYZ926 Posted January 11 Report Posted January 11 39 minutes ago, WRYS709 said: Retry your experiment with Input Tones on these channels if you have time, and report bach. I did try with and without tones set on my HT and base radio Quote
