  2. I will wager this statement will prove false.
  3. Notice, I stated the primary purpose is to pass data. I did not state a fixed station was data only nor reference nor imply that was their only use.
  4. Today
  5. I am trying to switch between dual display and single display on my KG-1000G Plus. When I hit the TDR button on the mic (#8) all I get is a double beep. When I enter the TDR function in any of my channels I also just get a double beep. Also when I press the AREA button I get a double beep. I want to stay in single display mode and customize the text in the unused area. Somehow, when I was trying to do this the unused area now says RPT-TX all the time. The owners manual is not much help. Any help is appreciated. Thanks!
  6. FCC Part 95 Subpart A - 95.303 Definitions: Base station. A station at a fixed location that communicates directly with mobile stations and other base stations. Fixed station. A station at a fixed location that directly communicates with other fixed stations only. The Term "DATA" Is Not Referenced In These Definitions For The Type Of Transmission. https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-A
  7. Don’t forget WiFi, Bluetooth and satellite radio/TV.
  8. Guest
    Chirp for Baofeng F22
    Sincere apologies to all. Thanks for the info. I won't ask any more questions.
  9. Congrats...hope you make many contacts
  10. And most phone land lines are now VOIP which is also digital.
  11. You can quit using your cellphone. It’s based on wireless two-way radio and digital voice technologies.
  12. I follow this type of programming scheme also. Local (Phoenix) Northern Az, Southern Az Western Az, Eastern Az. Both portable and mobile are set up the same exact way. Only difference is I have a few less zones on mobile as I can put more channels in there for a bank. I did 2 friends like this and the like it also. This way when traveling they just go to that zone to listen to traffic. (Scan list is by zone also but user programmable)
  13. OUCH!!!! I bet the doctor kicked himself over that. We have an issue with our Motorola Quantar 2m repeater. The inrush when it first transmits will trip the 12v dc to 120v ac inverter. The only way to get around that was to put a line conditioner in between the repeater and the inverter. One of our older club members was trying to catch the inrush to see how many amps it was with an old, but good, analog amp meter. He learned right away that an analog meter was not quick enough to catch the inrush. My new Klein CL800 just barely caught it. We never did find the exact fix for the inverter throwing a ground fault and shutting down when the Quantar firsts transmits. The Tripp Lite power conditioner is the only way to keep that from happening. The weird thing is that our older Motorola 70cm repeater and our Bridgecom GMRS repeater are both plugged into the inverter and there are no issues.
  14. I have another story about my original 87. I was doing an install on a 65 ft yacht belonging to a thoracic surgeon. Doc was on the boat while I was doing the work and saw my meter and picked it up and looked at it. He asked me where on the quality hierarchy the Fluke digital meters were. I told him they were top of the line, state of the art. Politely putting it down he cussed. I asked him why and he told me about his college roommate calling him up and asking him if he wanted to invest in his family business that was about to expand and go digital. He said "No thanks John. Those Simpson 260 analogs we used in physics class years ago will continue to be the industry standard for decades and decades to come." ... his roomy was John Fluke Jr.
  15. At one point there was a free upgrade to the bigger white display for the original 87. All you had to do was send them a postcard with the serial number of your 87. I carried and used mine everyday for over 25 years until just about everything was worn out. Bought a new series V about 6 years ago. I bought the original when I was trying to resolve a harmonic problem that was overheating and blowing fuses on a rooftop HVAC unit. After the fuse there was a coil of excess length feed wire that had suspicious melted insulation in a reoccurring pattern. I removed that and it didn't help, so I made a slight change to the wire before the fuse and all was resolved. I bought the Fluke because someone told me the Beckman 110+ I was using wasn't enough to measure what was going on.
  16. Maryland's cell phone law says "cell phone". Someone got a ticket using his ham radio, took it to court and won. Precedent set, in MD, using a 2 way radio while driving is OK.
  17. This is true. When you play stupid games, you win stupid prizes.
  18. Tune your antenna and they'll just work
  19. All of the Ghost antennas i've tested (more than just one brand) all performed better than the UT-72G antennas I tested them against .. that should give a baseline that they aren't as bad as "some people" repeatedly claim.
  20. I really like the Ghost. It performed much better than I expected it to. It does seem like a good choice for heavy equipment.
  21. Once again, if he weren't being an ass and interfering with official operations, he would have never come to the attention of the FCC and they would have never known what kind of radio he was using. Don't be an idiot.
  22. Not quite, fixed stations are primarily used to pass DATA between two fixed locations i.e. flood monitoring stations and monitoring posts. "Base" stations are control sites which activate repeaters or fixed stations to report. Base stations are at either permanent or temporary locations and are used to pass both data and voice to other base stations or mobile stations either through repeaters or directly. This implies there are three classes of stations, fixed stations reporting to another, single, fixed station, control stations, which may serve as both control and base stations and mobile stations which have no permanent location.
  23. After using the 42" and 18" Abbree "tactical tape measures" for a month, I have to say I'm impressed. The 42" gets as good or better SWRs across MURS, GMRS, 2m, and 70cm than the Comet 2x4 and doesn't need a ground plane. I tested it by hanging it from a rafter, so no ground plane was available. I can't say whether it actually outperforms the Comet in real-world use, because in the areas where I use my radios most, almost any antenna can get through. I can say, though, that with the Abbree and the Comet, I can use a repeater 22 miles away on one watt, which I can't do with any other antenna, but the Abbree is far more convenient to lug around. The 18" Abbree performs as well as the Nagoya and HYS 771s. Again, I can't say for sure that one is better than the other, because I don't have a particularly challenging environment, but it's certainly not worse than the others. Plus, a black AR-152 just looks badass with that antenna on it. I liked the multi-band TTM so much that I bought the GMRS version. I also tested it with a Nano VNA hanging from a rafter with no ground plane, and its SWRs were good enough, approaching 2.0:1 below 462.50000 and getting better from there. It's going into the bag with my portable repeater. I figure if I can get that thing 15'-20' up, I should get pretty good coverage. All in all, I'm quite satisfied with them. As I mentioned in the original post, they seemed a bit gimmicky, maybe more "cool" than practical, but I'm happy to report I was wrong.
  24. Martin aka WSCD723 made this post a year ago. I would guess that by now he has confirmed that his radios work.
  25. My bad. Someone musta bumped this old thread and I didn’t notice the date.
  26. Hi Dave, Gil, @wruu653, pointed out that the repeaters appear in a search if you turn on Stale and Offline repeaters. But then I found something weird, a mismatch (I think?) between map view and tabular view. If I do a tabular data repeater search to include stale and offline, both repeaters appear on the map. But if I go to map first and turn on those two switches for stale and offline, the repeaters don’t appear on the map. I have written to Rich, the site administrator, to learn what I might be doing wrong. Anyway, if you do a repeater search to include Stale and Offline repeaters, both Eureka repeaters appear in the list, allowing you to select them. If you do that they appear on the map and more importantly the owner’s call sign is available for you to contact him. You might want to contact the owner and ask him to update his data on the site.
