Once you receive your DM-32 please try this exercise and report back:
You are having a QSO on the Worldwide (91) chat group.
The other station suggests freeing up WW so that others can use it and asks you to continue the QSO on his local chat group: the Catawba Valley DMR 31678.
Will the DM-32 allow you to immediately switch over to and communicate on 31678 without having to program that Talk Group into the radio either ny hand or computer?
A shame that a radio as complicated as DMR does not come with its programming cable included.
I suspect that, similar to the Baofeng DM-5R and DM-1701, the chip is already in the radio and the USB cable is just a passthru that does not include a chip.
Also check out the Radioddity DB20-G a/k/a Anytone AT-779UV mini-mobile: 20 watts, mic controls, cigarette lighter plug, $99-$109
Add a $20 mag-mount antenna and Amazon cup-holder mount and it easily installs/uninstalls in your vehicles.
5 watts vs 2 and optionally external antennas on your vehicles will make a big difference.
And of course your GMRS license extends to other certain family members.
I often read many complaints about Midland radios on this forum and they seem to be overpriced
Although it looks similar, the TYT UV-88 is not the same radio as the Radioddity GM-30.
Channels 8-14 are not the same power limit as other GMRS or even FRS channels. Thay are specifically limited to .5 watt.
The GM-30 is certified for GMRS and so it satisfies FCC rules for GMRS.
Yes if you get a specific tool and loosen the nut, the antenna can be removed; but this does not break certification.
GMRS radios can have removable antennas. You are confusing FRS radio specs.
GMRS HTs can transmit on Channels 8-14.
Like Mr Natural says: “Get the right tool for the job!”
Radioddity and Baofeng offer many budget priced certified radios for GMRS, FRS and MURS, as needed.
My comment was about GMRS certified radios in general and in that context, I mentioned that FRS radios do not contain Repeater channels.
The fact of the matter is that the Baofeng UV-5RM is a ham radio and hence can never be certified for use on GMRS.
Yes: repeaters use an “offset” to receive on one frequency and then retransmit the signal on their main output frequency.
For GMRS, that offset is 5 MHz and the DB20-G is preset for that offset on channels 23-30.
So when you transmit on Channel 15 it both transmits and receives on 462.550. Whereas on Channel 23, it also receives on 462.550 but transmits on 467.550.
The tone is used by the repeater to determine if your signal should be retransmitted by the repeater on the offset frequency or not.
What’s even more confusing is that the premise in OP’s initial post (that the FRS channels are different than the GMRS channels), has been removed over time!
