Elkhunter521
    14
Everything posted by Elkhunter521
  1. One last point. Your radio cannot input a different pl tone for tx, and rx. This is just one of the shortfalls of the Mxt, line of radios.
  2. Hi, "Log in required" means you must log in to that page of MY GMRS.COM. (seperate log in) "Open" means anyone can use the repeater without prior permission from the owner. Hope this helps. Keith T
  3. Ok, to clarify my original request. A GMRS radio, with channels 15 - 22 simplex and duplex (repeater capable). Wide band, above 25 watt on tx. With the ability to set any tone or no tone on tx and rx. Still at $ 150 .
  4. Recognizing my desire to be 100% legal and managing to partially supress that desire, what radios would meet my "list" accepting the part 95 cert.?
  5. Wow, I guess i'm stupid. I do not understand why a China or any other place cannot build and get certified a radio with the following.(pay attention Midland): 1. Wide band channels 15 - 22 simplex and duplex. 2. 40 t0 50 watt tx. 3. Ability to set seperate pl tones for tx, rx, including no tone. 4. Retail at $150 us dollars. Hey, this is a good list so far. What have I missed?
  6. Ian, you need to be careful believing what Btech says, even in print. Best to see if its listed with FCC as part 90 accepted. Keith T
  7. I have 2 Midland MXT radios, (275 & 400). I belive the reason that Midland MXT radios score high on GMRS mobile reviews is there are few, if any other FCC type 95 mobiles out there.
  8. I have a problem spending more money on a test meter than on the radio/antenna that Im testing. I use a MFJ874. Its not junk but not the best either. I have several meters I bought for CB, but they dont work above 140 Mhz.
  9. All gmrs repeaters are private. They operate at the sole discretion of the owner.
  10. Hmmmmmm, Common sense is an Uncommon thing.
  11. Josh, just make sure the screen does not say rp in front of the channel number, 15 - 22, and you will be in simplex mode just like the GTX1000 and will be able to talk between them,
  12. Josh, one point, all radios receive on channels 15 thru 22, 462.xxx. In repeater mode radios transmitt on 467.xxx but still receive on 462.xxx.( duplex ) The repeater is opposite, receiving on 467.xxx and transmitting on 462.xxx. Your XMT400 has 2 sets of channels. One simplex, one duplex. This is seperate from 467.xxx FRS channels 8 thru 14.
  13. With the MXT400 the offset is built in. Page 22 in your manual describes activating the repeater function. This only has to be done once, not for each repeater channel. After activation, scroll slowly thru channel 15 thru 22, the radio will then start over at rp15 thru rp22.
  14. Hi Josh, The MXT400 is repeater capable. (Lots of opinions about this radio, read appropriate forums.) The GTX1000 is simplex only. You can use channels 15 thru 22 in simplex mode with either radio. Make sure the MXT400 is showing the channel number without an "r" on the display (following the channel number )
  15. Hi Bud, Every state is different. I would Google "Hands free laws for (every state you drive in)" Example, WA state specifically exempts CB radios and ham radios. OR state allows usage of radios when used on the job (exempts ham radios).
  16. Hi Jones, Thank you, it all helps.
  17. Hi Harold, Welcome to the forum.
  18. Hi, It would appear that the FCC is a force of nature. By that I mean that it will follow the path of least resistance. It will comply with what ever makes the problem go away.
  19. Hi, welcome to the forum. Keith T.
  20. Hi Taco6513, The only benifit of stacking your antennas, considering the line of sight characteristics of the frequency, would be area saturation. A 3 element yagi would be simpler and more effective.
  21. Hi Steve, As long as you are using a FRS radio, including the GMRS / FRS combination radios that were re classified last year to FRS, you do not need a license and you can use them. If you take your own GMRS radio (not a bubble pack )to work, you would legally have to use your call sign. At that point, everyone with a beef about your company's use of this channel would be looking for you. Not worth it. Oh, Welcome to GMRS. Keith T.
  22. Thank you, "recieve frequency " brings it together.
  23. Question: Amature radio offsets for repeaters are designated either as a + or a -, with a standard amount of offset for that frequency. The + or - is what direction from the transmit frequency of the radio? Ff
  24. I was confused about "fixed" stations before this. Also about the usage of the 467mHz repeater frequencies. Wow, its amazing how just a little bit more knowledge can create a total absence of comprehension.
  25. Hi, I can address the problem with the Midland MXT 100. This radio is simplex only. It is not repeater capable, which is why the repeater input frequencies are not mentioned in your manual.
