AdmiralCochrane
    9
  1. Lucky in central MD. Good round tables on both ham and GMRS. When a couple guys start talking about the best pizza place we can have 6 or 7 in very good order for 15 or 20 minutes sometimes.
  2. SWR meter, nano NVA or some other expensive antenna analyzer
  3. You are in trouble again. He didn't understand your sarcasm.
  4. Usually not. It's the frequencies that are blocked, not the memory addresses.
  5. I think there is one in Chestertown and one in Still Pond Kent County MD Yeah, the Towson .600 rules Look at repeaterbook.com so see more
  6. and he has read every word of this without saying a damn thing
  7. That is surprising. Reinforces my opinion about Midland's priorities. They are the KINGS of GMRS marketing.
  8. I'll try to poke around and figure it out
  9. They have pills for that now.
  10. Shaking Elvis's hand would be icky considering how long he's been cold. Meeting him would be even worse, because that would mean I was with him. Not sure if Randy has been complimented or insulted.
  11. I have been able to tilt my HT far enough out of polarization to have my signal go from full readable to barely readable when in contact with a repeater 20 miles away. Also whether the ISS repeater was readable or not (yes, with a regular verticle on a HT).
  12. Anything by Comet, Browning or Diamond. In reality you could even use a Nagoya. Don't use RG8 coax that you have on your VHF, 65cm UHF doesn't propagate thru RG8 as well as VHF does. Look for LMR-400 or equivalent. Marine band 156mhz (1.9 meter) is almost in the 2 meter ham VHF band, GMRS is 65cm is the next door neighbor of ham 70cm. A dual band 2 meter/70cm ham antenna won't be PERFECT but likely close enough for both radios to be compatible. My 2m/1.25m/70cm Comet tests pretty good for GMRS on a SWR meter and nanoNVA, well under 1.3:1 across GMRS.
  13. A bit louder and clearer, but you probably won't get a lot more distance. Height is might. Obstructions can't be overcome with power (unless you are lucky with refraction).
  14. 2 of them. Also got a little package from a fellow ham on the island of Malta
  15. Next you are going to tell us the emperor has no clothes
  16. Shame on you Randy, you got Marc hooked on 4 wheeling. His kids will starve now.
  17. I have that antenna. There is nothing high-capacity about it. IDK why he is worried about hydration, DE is so flat the water won't roll off of it.
  18. Completely different frequencies and propagation effects, but GMRSers might be suprised to learn on HF (short wave) some hams get lucky and bounce signals all the way around the world with 10 to 20 watts. Back to relevant bands and frequecies, you can communicate with the ISS with a regular 50 watt VHF or UHF transceiver. Using a Baofeng HT I have listened in on hams using the ISS repeater to make contacts with other hams. Knowing the antenna polarization and sweeping thru the frequencies made it better as did waiting for a high overhead pass. It is about the antenna and knowing what to do with it
  19. I have confirmed that it does give a minimal amount of help at the fringes. I also confirm that it does matter which way it faces. Apparently adds a little bit of antenna polarization. A location where I routinely activated a repeater from 18 or 20 miles away from the top of a 14 story building I could also work the repeater from ground level with the tiger tail oriented toward or away from the repeater but not perpendicular to the repeater. It did not make my signal understandable. From the roof with the tiger tail my signal report was no detectible difference hanging down but the same + at 0° and 180° and some decrease at 90° and 270°. Without the tiger tail I could make a difference by moving to different spots on the roof. I knew exactly where to stand to get the best propagation. If you are using a rubber duck, factory original garbage or counterfeit Nagoya a tiger tail isn't going to help as much as a buying genuine Nagoya.
  20. Yes, the permit would actually be for breaking the ground and installing a permanent structure. The antenna nor tower is actually the permanent structure that a dugout and poured base would be.
  21. Height equals might. Put up a tower first. A repeater without a tower doesn't do much of anything. An antenna mounted on a tower may be all you really need.
  22. 102 works for me too, but I try to tune them ahead of time with a NVA
  23. Only 100% symetrical ground planes don't cause propagation distortion. Don't worry that much about it. In my experience using field strength meters, mounting an antenna on a corner of a vehicle does cause the signal to be stronger across the vehicle to the opposite corner and 180° diagonally behind the vehicle. Dead center front or back sends the strongest signal in those directions, but it's only a few db. Any advantage or disadvantage would only come while the vehicle was stopped and you are making fringe contacts. Ability to mount the antenna higher will be more helpful than where on the vehicle.
