TerriKennedy Posted Tuesday at 06:21 AM Report Posted Tuesday at 06:21 AM When I'm conducting tests (on air and not into dummy loads) I announce my call sign and "Testing" and when done, my call sign and "Clear". That way if I'm interfering with someone they can specifically refer to me by call sign to get my attention. If I hear a request for a radio check I'll reply with my call sign "copies you 5 by 5" or whatever reception quality I think I'm receiving. There's a couple of guys who rag-chew for several hours on .700 simplex every evening without ever IDing. Most boring conversation imaginable. My repeater ID's every 15 minutes if continually up, then 15 minutes after the last transmission and then goes silent until somebody keys it up again. There are some near me that ID every 15 minutes in both Morse and voice and announce the (incorrect) time regardless of traffic (and I've never heard any traffic other than the automated announcements). WRUU653, WRCZ387 and SteveShannon 3 Quote
WSHH887 Posted Tuesday at 08:04 PM Report Posted Tuesday at 08:04 PM I'm sure glad I made popcorn for this. Quote
LeoG Posted Tuesday at 08:13 PM Report Posted Tuesday at 08:13 PM Make more. It's not going to end soon. Davichko5650 1 Quote
SteveShannon Posted Tuesday at 08:19 PM Report Posted Tuesday at 08:19 PM 1 minute ago, LeoG said: Make more. It's not going to end soon. That is correct. There are several other threads that started with someone pontificating about how others use GMRS incorrectly. None of them settled anything. This is one place where GMRS is similar to ham radio; someone thinks their way is “the only right way” even though the regulations don’t support that. amaff, WRYZ926, WRUU653 and 2 others 5 Quote
WRYZ926 Posted Tuesday at 10:24 PM Report Posted Tuesday at 10:24 PM That's why I made my comment about people needing to eat a Snickers Bar as they seem to be very hangry over stuff that doe not matter. In the end it doesn't really matter how you use GMRS as long as you follow the FCC regulations and guidelines. Same goes for amateur radio too. BoxCar, SteveShannon and WRUU653 1 1 1 Quote
UncleYoda Posted Tuesday at 11:48 PM Report Posted Tuesday at 11:48 PM 1 hour ago, WRYZ926 said: ...very hangry over stuff that doe not matter. ...as long as you follow the FCC regulations and guidelines. Doesn't following the regs matter? Many, maybe most, are not. I'm also curious how we are supposed to detect who is an FRS user. Quote
WRUE951 Posted Wednesday at 12:27 AM Report Posted Wednesday at 12:27 AM 4 hours ago, WSHH887 said: I'm sure glad I made popcorn for this. i mixed a barch with caramel.. May as well enjoy irt Davichko5650 1 Quote
WRYZ926 Posted Wednesday at 12:46 AM Report Posted Wednesday at 12:46 AM 53 minutes ago, UncleYoda said: Doesn't following the regs matter? Many, maybe most, are not. I'm also curious how we are supposed to detect who is an FRS user. Yes following the regs does matter and why I stated the following: 2 hours ago, WRYZ926 said: In the end it doesn't really matter how you use GMRS as long as you follow the FCC regulations and guidelines. One really can't tell if someone is on a FRS radio or GMRS radio when using simplex channels as the FCC messed up when they allowed both services on the same channels. Obviously you won't ever hear a FRS radio on the GMRS repeater channels. Again. GO with what works for you on how often you say you call sign as long as you are at a minimum giving it every 15 minutes and at the end of your conversation. SteveShannon 1 Quote
OffRoaderX Posted Wednesday at 12:47 AM Report Posted Wednesday at 12:47 AM 1 minute ago, WRYZ926 said: Obviously you won't ever hear a FRS radio on the GMRS repeater channels. Please explain this one to us... Quote
WRYZ926 Posted Wednesday at 12:49 AM Report Posted Wednesday at 12:49 AM Just now, OffRoaderX said: Please explain this one to us... EASY PEASY that even a lowly Private can understand. Legal FRS radios can't transmit on the GMRS repeater channels. All bets are off if someone is using an unlocked radio. Quote
OffRoaderX Posted Wednesday at 12:55 AM Report Posted Wednesday at 12:55 AM 7 minutes ago, WRYZ926 said: EASY PEASY that even a lowly Private can understand. Legal FRS radios can't transmit on the GMRS repeater channels. All bets are off if someone is using an unlocked radio. Uh huh.. Then... Why do I hear FRS radios every time I'm on any of the GMRS repeater channels? and, why can I hear all of my locked/legal FRS radios on the GMRS repeater channels ? I am very confused. WRUE951 1 Quote
UncleYoda Posted Wednesday at 12:59 AM Report Posted Wednesday at 12:59 AM 6 minutes ago, WRYZ926 said: All bets are off if someone is using an unlocked radio. That, or what I suspect I'm hearing, GMRS radios being used as FRS radios with no ID. Quote
LeoG Posted Wednesday at 01:05 AM Report Posted Wednesday at 01:05 AM 15 minutes ago, WRYZ926 said: EASY PEASY that even a lowly Private can understand. Legal FRS radios can't transmit on the GMRS repeater channels. All bets are off if someone is using an unlocked radio. Can't transmit into a repeater. Can absolutely transmit on ch 550-725 amaff 1 Quote
WRYZ926 Posted Wednesday at 01:07 AM Report Posted Wednesday at 01:07 AM Just now, LeoG said: Can't transmit into a repeater. Can absolutely transmit on ch 550-725 I should have been more precise in my statement by saying that a FRS radio can't transmit on GMRS repeater channels. I never know when a simple answer or a precise answer is needed around here. Quote
OffRoaderX Posted Wednesday at 01:15 AM Report Posted Wednesday at 01:15 AM 8 minutes ago, WRYZ926 said: I never know when a simple answer or a precise answer is needed around here Always write to the lowest common denominator. Quote
LeoG Posted Wednesday at 01:25 AM Report Posted Wednesday at 01:25 AM So you are here talking to a bunch of tech radio dorks and you think it's OK to be vague. OK. amaff 1 Quote
SvenMarbles Posted Wednesday at 02:38 AM Author Report Posted Wednesday at 02:38 AM On 7/14/2025 at 7:23 PM, SteveShannon said: This doesn’t sound “utilitarian”. In fact it sounds pretty social. § 95.1731 Permissible GMRS uses. The operator of a GMRS station may use that station for two-way plain language voice communications with other GMRS stations and with FRS units concerning personal or business activities. Well it’s right there.. Personal and business activities. Concerned parties. Not “making contacts” across licenses. SteveShannon 1 Quote
LeoG Posted Wednesday at 03:03 AM Report Posted Wednesday at 03:03 AM Define personal activities. Quote
OffRoaderX Posted Wednesday at 03:08 AM Report Posted Wednesday at 03:08 AM 3 minutes ago, LeoG said: Define personal activities. "Making contacts" with anonymous men certainly counts as a personal activity... Very.. very personal.. AdmiralCochrane, marcspaz and WRUU653 3 Quote
SteveShannon Posted Wednesday at 03:43 AM Report Posted Wednesday at 03:43 AM 20 hours ago, SvenMarbles said: Well it’s right there.. Personal and business activities. Concerned parties. Not “making contacts” across licenses. Sven, I think you’ve lost your marbles, That’s exactly why we have call signs and why we’re required to use them: to identify ourselves to others and have a way to look them up when we engage in the personal or business activities of “making contact”. Although it’s not explicitly encouraged like ham radio it’s absolutely not discouraged in any way, explicitly or implicitly. hxpx, WRXB215, AdmiralCochrane and 1 other 3 1 Quote
hxpx Posted Wednesday at 02:36 PM Report Posted Wednesday at 02:36 PM 11 hours ago, OffRoaderX said: "Making contacts" with anonymous men certainly counts as a personal activity... Very.. very personal.. "Well, you see, little Timmy, sometimes a man buys a radio so he can meet other men and exchange signal reports and talk about antennas." "What about talking to friends and family?" "Yeah yeah, they do that too, but first, let's talk about mag mounts and ground planes..." marcspaz, bscabl and WSEL330 3 Quote
73blazer Posted Wednesday at 05:56 PM Report Posted Wednesday at 05:56 PM On 7/15/2025 at 2:21 AM, TerriKennedy said: There's a couple of guys who rag-chew for several hours on .700 simplex every evening without ever IDing. I've never heard the likes of such behavior. No ID. Well. How uncivilized. I bet they use DCS tones too. What has this world come to?!?!?!?! SteveShannon 1 Quote
WRTC928 Posted Wednesday at 08:12 PM Report Posted Wednesday at 08:12 PM 20 hours ago, UncleYoda said: I'm also curious how we are supposed to detect who is an FRS user. To the best of my knowledge, there is no way to do that. Quote
Davichko5650 Posted Wednesday at 08:17 PM Report Posted Wednesday at 08:17 PM 6 hours ago, hxpx said: "Yeah yeah, they do that too, but first, let's talk about mag mounts and ground planes..." But it is vitally important, if not imperative that they first discuss their recent Bunionectomy and the status of Myrna Mae's Hernia prior to getting into the nuts an bolts of antennae... OffRoaderX 1 Quote
marcspaz Posted Wednesday at 08:41 PM Report Posted Wednesday at 08:41 PM I wish it was that boring around here. We have the most uncouth people on the radio around here. One lady got on the repeater (not simplex) to tell her husband to go break-up the kids from fighting because she was taking a crap and couldn't get off the commode. WSEL330, amaff, SteveShannon and 1 other 3 1 Quote
