gman1971 Posted April 18, 2020 Report Posted April 18, 2020 Would be awesome if they moved the manufacturing back to the USA... but I won't hold my hopes very high... Mikeam and sifert 2 Quote
rdunajewski Posted April 18, 2020 Report Posted April 18, 2020 I've reached out to my reps at Midland and they said nothing new in the Spring, and nothing to announce for later in the year yet. I think any plans they had are put on hold because of the pandemic. I'd expect something out by Q1 2021 realistically. Ian, gortex2 and sifert 3 Quote
Jones Posted April 18, 2020 Report Posted April 18, 2020 Would be awesome if they moved the manufacturing back to the USA... but I won't hold my hopes very high...Back to the USA? I don't think Midland ever had anything made here in the first place. ..but yes,it would be nice if ANY consumer electronics company made products in the USA.... really MADE products here, not just assembled from Asian modules. Quote
russwbrill Posted April 18, 2020 Author Report Posted April 18, 2020 I've reached out to my reps at Midland and they said nothing new in the Spring, and nothing to announce for later in the year yet. I think any plans they had are put on hold because of the pandemic. I'd expect something out by Q1 2021 realistically. Hey Rich, Anything new with the added features in the next 12 months would be nice.. And that Q & A tells us Midland has been listening to their customers! 73,Russ Mikeam 1 Quote
russwbrill Posted April 23, 2020 Author Report Posted April 23, 2020 Of course there are other products (B-Tech) available with lots of features, but the quality seems VERY Low!!! Quote
isherman Posted April 26, 2020 Report Posted April 26, 2020 Any possibility they could do a firmware update using the data port on the radios like the mxt400? It would make the most sense to current owners. Quote
berkinet Posted April 26, 2020 Report Posted April 26, 2020 Of course there are other products (B-Tech) available with lots of features, but the quality seems VERY Low!!!And, Wouxun. Good quality, Good feature set, responsive to customers, and available right here. scottmckinney67 and Extreme 2 Quote
marcspaz Posted April 26, 2020 Report Posted April 26, 2020 Any possibility they could do a firmware update using the data port on the radios like the mxt400? It would make the most sense to current owners.Its unlikely flashing existing hardware will be an option. The electronic components used to make filters are designed for narrow use and may not be tuned properly for just a reflash. Think of it like a car on the highway. If you have a car that can travel at 200mph and the speed limit is raised to 200mph, you're good to go. However, if your car has a top speed of 80... it doesn't matter how high the speed limit is. You would have to re-engineer the car to go faster. Quote
Ian Posted April 30, 2020 Report Posted April 30, 2020 Its unlikely flashing existing hardware will be an option. The electronic components used to make filters are designed for narrow use and may not be tuned properly for just a reflash. Think of it like a car on the highway. If you have a car that can travel at 200mph and the speed limit is raised to 200mph, you're good to go. However, if your car has a top speed of 80... it doesn't matter how high the speed limit is. You would have to re-engineer the car to go faster.I'm not sure, really the only thing that would need much changing is control logic. Sure, you'd be limited to the power your final amp is good for, but you could get some nice quality-of-life features like two repeaters on one frequency, at least without soldering (if they picked capable enough microcontrollers, at least). Quote
marcspaz Posted April 30, 2020 Report Posted April 30, 2020 I wouldn't rule it out as a possibility, for sure. Quote
ChiRider19 Posted May 17, 2020 Report Posted May 17, 2020 I'm somewhat of a newbie, and I'm considering getting either the mxt115 or mxt275 and I can see the advantage that the 275 has with the integrated controls on the handset. Why would anyone choose the 115? It costs the same and has pretty much the same specs except that all the controls are on the base unit. Am I missing something? Can anyone who's had experience with both, tell me what advantage that the 115 has over the 275? Quote
gortex2 Posted May 17, 2020 Report Posted May 17, 2020 All preference. I have both. I use the HHCH in my Jeep and the other radio in my Motorhome. Quote
ChiRider19 Posted May 22, 2020 Report Posted May 22, 2020 All preference. I have both. I use the HHCH in my Jeep and the other radio in my Motorhome.Thanks for the feedback. I just bought a couple of mxt275s Quote
ChiRider19 Posted May 22, 2020 Report Posted May 22, 2020 Has anyone used any of the Midland repeater capable gmrs radios with a repeater? If so, how do they perform? Quote
Ian Posted May 22, 2020 Report Posted May 22, 2020 Has anyone used any of the Midland repeater capable gmrs radios with a repeater? If so, how do they perform?I have. They're ... adequate. When I have coverage, it'll take the radio from one end of the island to the other, where simplex is completely out of the question. Quote
berkinet Posted May 22, 2020 Report Posted May 22, 2020 Has anyone used any of the Midland repeater capable gmrs radios with a repeater? If so, how do they perform? Several members here have done so. Search the forums for reports. There seem to be three issues that are commonly reported and which may, or may not, be important to you. The Midland radios operate on narrow-band FM while most repeaters operate on wide-band FM. This tends to result in the Midland's broadcasts being heard at a lower volume by listeners. The Midland radios must use the same tone or digital squelch on transmit and receive. So, if you have a repeater that uses different schema on transmit and receive, you will not be able to easily use the repeater. The Midland is missing a small number of PL tones. If a repeater requires one of those tones, you will not be able to access it.Again, I suggest you search the forum for reports and to determine if these issues are significant for your planned usage. And, note also, the built-in search feature tends to miss things. I'd suggest doing a google search for something like:site:forums.mygmrs.com midland review repeater 8nannyfoe, ratkin, ChiRider19 and 1 other 4 Quote
ChiRider19 Posted May 22, 2020 Report Posted May 22, 2020 I have. They're ... adequate. When I have coverage, it'll take the radio from one end of the island to the other, where simplex is completely out of the question.Thanks for the feedback Ian! Quote
ChiRider19 Posted May 22, 2020 Report Posted May 22, 2020 Several members here have done so. Search the forums for reports. There seem to be three issues that are commonly reported and which may, or may not, be important to you. The Midland radios operate on narrow-band FM while most repeaters operate on wide-band FM. This tends to result in the Midland's broadcasts being heard at a lower volume by listeners. The Midland radios must use the same tone or digital squelch on transmit and receive. So, if you have a repeater that uses different schema on transmit and receive, you will not be able to easily use the repeater. The Midland is missing a small number of PL tones. If a repeater requires one of those tones, you will not be able to access it.Again, I suggest you search the forum for reports and to determine if these issues are significant for your planned usage. And, note also, the built-in search feature tends to miss things. I'd suggest doing a google search for something like:site:forums.mygmrs.com midland review repeaterThanks! That's very helpful information. I'll search the threads. Hopefully Midland can address some of those inadequacies in future versions. Quote
fremont Posted June 25, 2020 Report Posted June 25, 2020 I'd like to have a mobile unit (in addition to my BTech GMRS-V1) in time for hunting season. Processing these choices (are there more?): 1. Get BTech GMRS-50X1 now;2. Wait for Midland's new mobile unit; or3. Step up to pricier options. Quote
tweiss3 Posted June 26, 2020 Report Posted June 26, 2020 Look for a used Kenwood that is part 95, I love mine, excellent audio quality. Quote
Ccleveland1226 Posted June 26, 2020 Report Posted June 26, 2020 I have a midland mxt275 in my truck, I know it isn't the greatest radio, but it works for me and the price was right. Bought it on sale direct from midland for around $130 gortex2 1 Quote
shawnvanhorn Posted July 1, 2020 Report Posted July 1, 2020 I have read on another Forum where if you order the DBR1 cable directly from Midland, and then contact them and tell them you need a copy of the Programming software for ONLY the Midland MXT 400, that you can open the software up and make it split and open up the band for the repeater channels. His name is John Whitt. He talked to a man named Roger at Midland and he emailed a Zip file with the software, so maybe there is help for at least the Midland MXT-400. Quote
berkinet Posted July 1, 2020 Report Posted July 1, 2020 ...you can open the software up and make it split and open up the band for the repeater channels. ...That is an interesting report. Unfortunately, I am not really sure what it is you are describing. I am guessing when you say make it split, you mean use different PL tones on transmit and receive. But, I am unclear about open up the band. If this were to allow reception from frequencies outside of GMRS, that would make sense. However, if it means allow transmitting on frequencies outside of GMRS, that would certainly nullify the Part95 certification, one of the major benefits of the radio. So, more information would be much appreciated. Thanks Quote
JLeikhim Posted July 2, 2020 Report Posted July 2, 2020 What Midland ought to do is concede that their narrow band radios are a mistake and release a new model that will properly do wide-band. Add 8 WB repeater pairs 23-30 . They could also do it through the menu and make the RP light flash when WB mode is selected. WB then could apply to all the GMRS channels, simplex or repeater. The question is, do they have a WB filter in the RX path? If it is SDR then it is math unless it is burned into a chip. Then you have that pesky modulation fidelity to be optimized for 16K0F3E. Not sure they can properly do 11K0F3E now. UHFJim 1 Quote
