mbrun Posted July 16, 2020 Report Share Posted July 16, 2020 About 10-years ago when I obtained my original GMRS license the FCC had a limit on GMRS antenna height. It was 20 foot above the tree or building to which it was mounted (roughly speaking). In the current regulations that 20 foot limit seems to have been complete removed. Instead, 95.1741 (regarding height) merely redirects to 95.317 that seems to indicate antennae structure over 200 foot may need to be registered with FAA. So, I am curious, has the 20 foot limit truly been removed? Is it now 200 feet? If restriction is specified somewhere else if the CFR, where would I find it? Michael Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
rodro123 Posted July 17, 2020 Report Share Posted July 17, 2020 § 95.51 Antenna height.(a) Certain antenna structures used in a GMRS system and that are more than 60.96 m (200 ft) in height, or are located near or at a public-use airport must be notified to the FAA and registered with the Commission as required by part 17 of this chapter. Antenna height. Quote Link to comment Share on other sites More sharing options...
BoxCar Posted July 17, 2020 Report Share Posted July 17, 2020 The 6.1 meter (20 foot) rule does not apply in this instance. If the height of the structure AND antenna is greater than 200 feet overall it needs to be registered. Several Part 90.20 entities found this out when the FCC cited them. Quote Link to comment Share on other sites More sharing options...
mbrun Posted July 17, 2020 Author Report Share Posted July 17, 2020 § 95.51 Antenna height.(a) Certain antenna structures used in a GMRS system and that are more than 60.96 m (200 ft) in height, or are located near or at a public-use airport must be notified to the FAA and registered with the Commission as required by part 17 of this chapter. Antenna height.Rodro123, I believe 95.51 was removed as part of the 2017 FCC update. My current understanding is that 95.1741 took its place. Sent from my iPad using Tapatalk berkinet 1 Quote Link to comment Share on other sites More sharing options...
berkinet Posted July 17, 2020 Report Share Posted July 17, 2020 .,,95.51 was removed as part of the 2017 FCC update. My current understanding is that 95.1741 took its place. ...That is correct. However note that part 95.51 then refers to 47 CFR § 95.317 which provides restrictions for all personal radio services under part 95. However, the restrictions are pretty much the same as they were under section 95.51. But with the addition of additional restrictions if you’re near a military installation or airport. Quote Link to comment Share on other sites More sharing options...
mbrun Posted July 17, 2020 Author Report Share Posted July 17, 2020 So are you concluding that the limit is 200 feet, the same as I am? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
berkinet Posted July 17, 2020 Report Share Posted July 17, 2020 So are you concluding that the limit is 200 feet, the same as I am? Absent any other circumstances, yes. Quote Link to comment Share on other sites More sharing options...
tweiss3 Posted July 17, 2020 Report Share Posted July 17, 2020 To clarify further for you guys, that 200' limit is the cutoff for requiring FCC/FAA filing and paint/lights. You can go above 200' if you want to deal with the hassle. rdunajewski and berkinet 2 Quote Link to comment Share on other sites More sharing options...
BoxCar Posted July 17, 2020 Report Share Posted July 17, 2020 IIRC the FAA regs state the structure has to have a light at its highest point. It's difficult to get an antenna to work properly when it has a light and power cable on it. The issue was uncovered when antennas started being put on bridges more than towers, Quote Link to comment Share on other sites More sharing options...
mbrun Posted July 17, 2020 Author Report Share Posted July 17, 2020 My ultimate reason for asking the question has to do with my surroundings. My home is surrounded by acres of trees on three sides. I am considering an antenna on the home and originally figured 20’ above the home. But then I thought, I wonder if I could attach to house but put up high enough to peek out above the trees. Not sure if I will do that or not, but its sounds like that is legal if I decided to go that way. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
JohnE Posted July 17, 2020 Report Share Posted July 17, 2020 what is it going to take to clear the trees.also what are the local rules on antenna height. some places have restrictions on height and fall zones. kmcdonaugh 1 Quote Link to comment Share on other sites More sharing options...
mbrun Posted July 17, 2020 Author Report Share Posted July 17, 2020 Good point on local ordinances. I will need to look into that. I image it would take 60 foot +/- to clear the trees. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
JohnE Posted July 17, 2020 Report Share Posted July 17, 2020 ran into that problem. found a way around it though. Quote Link to comment Share on other sites More sharing options...
mbrun Posted August 5, 2020 Author Report Share Posted August 5, 2020 I have ordered a Comet 712EFC Antenna and some LMR400 cable to begin testing at my place. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
n4gix Posted August 6, 2020 Report Share Posted August 6, 2020 I was once offered space on a very large tower array (2 towers with a bridge at the top) in Crete, Illinois. They had a UHF antenna and 1 1/2" hard line at 350'... I was all excited until I was informed that they charge $1/ft' per month. No way I could afford $350/month Quote Link to comment Share on other sites More sharing options...
mbrun Posted August 10, 2020 Author Report Share Posted August 10, 2020 A bit too much for the hobby of an individual I would say. I was once offered space on a very large tower array (2 towers with a bridge at the top) in Crete, Illinois. They had a UHF antenna and 1 1/2" hard line at 350'... I was all excited until I was informed that they charge $1/ft' per month. No way I could afford $350/month Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
dwmitchell61 Posted September 18, 2020 Report Share Posted September 18, 2020 I have ordered a Comet 712EFC Antenna and some LMR400 cable to begin testing at my place. Sent from my iPad using TapatalkTesting done? How did it go? What radio are you using? Quote Link to comment Share on other sites More sharing options...
mbrun Posted September 18, 2020 Author Report Share Posted September 18, 2020 Testing done? How did it go? What radio are you using?Yes and no. I have commented on some of my activities in other posts. At present, the highest I have been able to test has been 41’ to top of antenna. Still strategizing how I can the get the antenna to 60’ to button of antenna in a temporary manner at limited expense so more coverage tests can be performed. What I am wanting to determine is, if I clear the trees only marginally, will that get me the local simplex coverage I seek (solid coverage >= 3 miles base to HT and >= 9 miles base to mobile). If my simplex coverage does not increase notably at 60’, then I won’t go for the expense for permanent installation. I have been pondering the purchase of DX engineering 46’ telescoping mast, but that still does allow me to clear the trees. So yes, I am done testing for now. No, I have not completed testing at my desired height...yet. 73s MichaelWRHS954KE8PLM Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
mbrun Posted January 12, 2021 Author Report Share Posted January 12, 2021 I finally made the purchase of the HD 46’ push-up fiberglass mast I referenced in my earlier post. This weekend I rigged things up in a temporary way to conduct tests with local (and not so local) repeaters, as well as do some local simplex work. The image below shows my antenna at full elevation (56’ AGL to tip of Antenna). Mast was installed in a temporary way just for testing. Eventually it will get moved next to the house. Amazing how plumb the mast was being guyed only at 7’3” (not good long term, but good enough for testing). The antenna is a Comet 712EFC Collinear 9dBi.https://www.dxengineering.com/parts/cma-ca-712efCable is TMW LMR400Mast is from DX Engineering.https://www.dxengineering.com/parts/dxe-tfk46-hd All of my testing consisted of using two handheld 5w radios. One feeding the Comet antenna, one in the car using an MXTA-26 antenna. First, the high-point of the testing. I was able to communicate from my home southeast of Cincinnati to the Dayton 700 repeater located 50 miles north(straight line distance) using approx 3 watts of input power into the antenna. Signal report from a Dayton area resident was “very good” and “into the repeater solid”, perfectly suitable for a QSO. That alone made my weekend. On the local front I was able to get into three local repeaters located 20, 21 and 26 miles way. Got in with full quieting to the one 20 miles away (“just as though I was next door”), and with just a hint of noise on the ones 21 and 26 miles away. Getting the antenna up high obviously makes a huge difference. On the simplex front I found I could achieve pretty reliable coverage out 4 to 5 miles where things transitioned to hit and mis out to about 7-8 miles when all seemed to die completely. I expect the reliable range will decrease as foliage comes back. Not bad though for a couple of lower power HT and with good external antennas. It will be nice to experience the positive change to simplex coverage after I up the power of the base and mobile to legal limits. MichaelWRHS965KE8PLM n4gix, SUPERG900 and wayoverthere 3 Quote Link to comment Share on other sites More sharing options...
WRKC935 Posted January 12, 2021 Report Share Posted January 12, 2021 This needs simplified. Repeater antenna. No Limit to height in rules. In certain area's around airports FAA regulations limit the tower height. In all locations, towers exceeding 200 feet need to be registered with the FAA and lit with a type accepted lighting system.Base station antenna's. Meaning antenna at a fixed location that is talking and receiving from mobile and other bate stations where no repeater is involved. 50 feetControl Stations. Meaning a fixed station (base type station) that is communicating with an off site repeater to extend coverage. I believe is 20 feet (for sure with commercial radios but this run gets broken constantly)No limit on mobile / portable antennas that I have seen in rules. Quote Link to comment Share on other sites More sharing options...
MacJack Posted January 12, 2021 Report Share Posted January 12, 2021 Thanks Michael for sharing this... You're are a good teacher. JackI finally made the purchase of the HD 46’ push-up fiberglass mast I referenced in my earlier post. This weekend I rigged things up in a temporary way to conduct tests with local (and not so local) repeaters, as well as do some local simplex work.......................MichaelWRHS965KE8PLM Quote Link to comment Share on other sites More sharing options...
n4gix Posted January 14, 2021 Report Share Posted January 14, 2021 Control Stations. Meaning a fixed station (base type station) that is communicating with an off site repeater to extend coverage. I believe is 20 feet (for sure with commercial radios but this run gets broken constantly) Actually, the limit is 20' higher than the support structure. If one lived in the penthouse of a 40 story building, imagine the range one could enjoy even on simplex! AdmiralCochrane 1 Quote Link to comment Share on other sites More sharing options...
n4gix Posted January 14, 2021 Report Share Posted January 14, 2021 I finally made the purchase of the HD 46’ push-up fiberglass mast I referenced in my earlier post. This weekend I rigged things up in a temporary way to conduct tests with local (and not so local) repeaters, as well as do some local simplex work. <snipped for brevity>The antenna is a Comet 712EFC Collinear 9dBi.https://www.dxengineering.com/parts/cma-ca-712efCable is TMW LMR400Mast is from DX Engineering.https://www.dxengineering.com/parts/dxe-tfk46-hd That is a very nice antenna. I installed one on the roof of my house about seven years ago on a 20' mast secured by a heavy duty tripod. I went a bit overboard by using 7/8" Andrews heliax. It's been a rock-solid performer and has survived many gusts in excess of 60mph, and a derecho last year with highest steady winds of ~90mph! See: https://twitter.com/i/status/1292938287296974856 showing an apartment building being "de-roofed." Those masts are great, although measuring and marking each section and gluing the toggle clamps was a PITA! I have two of them and use the tall tripods from MFJ along with two levels of guy lines to support my G5RV (106' HF antenna) on field days and other club events such as POTA (Parks on the Air) activations. Quote Link to comment Share on other sites More sharing options...
mbrun Posted January 14, 2021 Author Report Share Posted January 14, 2021 You know, I was watching that video expecting to see an antenna still standing while the roof was ripped off. I read about the glue up PITA issue you talked about and was fretting it too. The version I received did not require glue. The couplers simply slide over the lower section and are tightened in place with an allen wrench. Nice! That is a very nice antenna. I installed one on the roof of my house about seven years ago on a 20' mast secured by a heavy duty tripod. I went a bit overboard by using 7/8" Andrews heliax. It's been a rock-solid performer and has survived many gusts in excess of 60mph, and a derecho last year with highest steady winds of ~90mph! See: https://twitter.com/i/status/1292938287296974856 showing an apartment building being "de-roofed." Those masts are great, although measuring and marking each section and gluing the toggle clamps was a PITA! I have two of them and use the tall tripods from MFJ along with two levels of guy lines to support my G5RV (106' HF antenna) on field days and other club events such as POTA (Parks on the Air) activations. MichaelWRHS965KE8PLM Quote Link to comment Share on other sites More sharing options...
AdmiralCochrane Posted January 20, 2021 Report Share Posted January 20, 2021 Actually, the limit is 20' higher than the support structure. If one lived in the penthouse of a 40 story building, imagine the range one could enjoy even on simplex! That's the only thing that makes me envious of the 15 story building at the top of my line of sight facing north. If we had a repeater up there, it would be golden Quote Link to comment Share on other sites More sharing options...
