mbrun Posted February 26, 2021 Report Posted February 26, 2021 I was looking up specs on something else and stumbled upon yet another entry into the GMRS HT world. https://www.buytwowayradios.com/wouxun-kg-905g.html MichaelWRHS965KE8PLM Shadow471 and Radioboy1962 2 Quote
MacJack Posted February 26, 2021 Report Posted February 26, 2021 Nice radio. So Michael, does it have option to select scan channels....JackI was looking up specs on something else and stumbled upon yet another entry into the GMRS HT world.https://www.buytwowayradios.com/wouxun-kg-905g.htmlMichaelWRHS965KE8PLM Quote
GuySagi Posted February 26, 2021 Report Posted February 26, 2021 According to the web page, "Sure, there are the standard features of GMRS handheld transceivers, such as channel scan, timeout timer, roger beep, button beeps and VOX, but that's just to be expected. Where The KG-905G really outclasses the competition is in its more advanced functionality." Quote
Extreme Posted February 26, 2021 Report Posted February 26, 2021 "CTCSS/DCS tone scan" is in the description. I tried to download the software to look for channel scan select buy my laptop tells me "Failed - virus detected". Quote
MozartMan Posted February 26, 2021 Report Posted February 26, 2021 "CTCSS/DCS tone scan" is in the description. I tried to download the software to look for channel scan select buy my laptop tells me "Failed - virus detected". Here are screenshots. Quote
OldRadioGuy Posted February 26, 2021 Report Posted February 26, 2021 Some nice features like a huge battery and power level select in menus.It says "waterproof" but it's only IP-66 which is just "water jet" proof - not submersible.Don't drop it while wading with your flyrod. My Cobra ACXT645's have tone scan but I've never tried it.I wonder if it's smart enough to only scan when a signal is present?Otherwise would be really hit-miss. I'm pretty happy with the 805G's and I wonder if my wife would "run away" from the 905G with "too many" features.I suppose the 805 is the same basic radio. Not necessarily obsolete... I hope. Vince Quote
mbrun Posted February 26, 2021 Author Report Posted February 26, 2021 "CTCSS/DCS tone scan" is in the description. I tried to download the software to look for channel scan select buy my laptop tells me "Failed - virus detected".On all radios I have with tone scan, it is a radio-only feature, not a software feature or option. On the radio you can select and activate it only while actively receiving a signal. It is not available to activate until then, but then stays active until turned off or the code is found. MichaelWRHS965KE8PLM Quote
MacJack Posted February 27, 2021 Report Posted February 27, 2021 Thanks MozartMan for screen shot. Question, I do not have a PC so can you tell me is there a difference in the Wouxun-KG-905G-Programming-Software to that of the Wouxun-KG-805G-Programming-Software? I'm wandering if I can use CHIRP with 905G. I will backup first if I get 905G.Jack Here are screenshots. Quote
MozartMan Posted February 27, 2021 Report Posted February 27, 2021 Question, I do not have a PC so can you tell me is there a difference in the Wouxun-KG-905G-Programming-Software to that of the Wouxun-KG-805G-Programming-Software? I'm wandering if I can use CHIRP with 905G. I will backup first if I get 905G.Jack Jack, First, similar thing is that both software have three screens. But it looks like there is a difference. 905 software have channels named kinda strange way, like this: G1-1------G1-16G2-1-------G2-16 and so on. The last channel is G16-16. Multiplying 16x16 and it looks like we get 256 memory channels. I will attach screenshots after I reduce file sizes of JPEG images. Had to upload images to the hosting website because could not reduce file sizes to under 80KB. Quote
MozartMan Posted February 27, 2021 Report Posted February 27, 2021 Here are screenshots for 805 Software. Quote
MozartMan Posted February 27, 2021 Report Posted February 27, 2021 Here is screenshots for 905G software. Quote
MacJack Posted February 27, 2021 Report Posted February 27, 2021 Well MozartMan that answered my question, thanks. So it looks like it is not the same program with different relational database/tables on your screen.. So what Windows does the 905G software say it needs. I may have to go to the flea market for a PC. Jack Quote
haneysa Posted February 27, 2021 Report Posted February 27, 2021 The 16 zones are appealing to me. It looks like the increasing demand in causing manufacturers to add features, and hopefully increase quality. I would like to see an IP67 rated HT and an IP67 mobile. I also think that they should be able to build a 50w mobile that can operate on the FRS shared channels at legal limits. Quote
mbrun Posted February 28, 2021 Author Report Posted February 28, 2021 ...I also think that they should be able to build a 50w mobile that can operate on the FRS shared channels at legal limits.Since 22 of the 30 GMRS frequencies are already shared with GMRS, I believe you likely referring to the 467 interstitial channels (channels 8-14) which have a 1/2 watt limit. There is no “technical reason” why it cannot be done, it most certainly can. I do believe there are a some reasons why it is not done.1) The GMRS radios being made for us are not from-the-ground-up radios. In most cases they are repackaged amateur radios that are already built for higher powers. Some have two, some have three power settings, none that I know of go down to 1/2 watt and below. I think that to do so would lead to higher cost radios with little or no net benefit to consumers.2) The FCC power limit for channels 8-14 is not 1/2 watt output power. It is actually 1/2 watt ERP which, by definition, means that the power rating must take into account the attached antenna system gain as well. Now, since FCC ERP definition is based on a dipole antenna, any user that uses an an antenna with a gain greater than a simple dipole (which is 2.1dBi) would be immediately in violation of the rules. Thus, if the manufacturers built their mobile radios to be legal, they would likely need to limit output power to somewhere around .07 watts to account for folks like me that use a 9dBi or 11dBi antenna. How many of you would be thrilled to buy a radio with a whopping spec of 1/16th of a watt? Not many I assume. We repeater uses absolutely do not want any more ERP on channels 8-14 than is currently allowed. Any extra power here will most certainly lead to degraded repeater performance, as these frequencies already overlap by 50% with the reserved repeater input frequencies. Add more power and suddenly the kids playing with their toy radios, and mobile radios on these frequencies will lead to you not being able to use the repeater well while in your car. Something to think about. MichaelWRHS965KE8PLM Quote
n4gix Posted February 28, 2021 Report Posted February 28, 2021 The major restriction however is that FRS capable radios cannot have removable antennas. Period. Quote
epasleyva Posted March 7, 2021 Report Posted March 7, 2021 Just got mine, just started testing and so far it looks like its going to be a great radio for the price. I live in Galax, Va, and on low power hit the Stone Mountain, NC repeater with a great signal report that is 31 miles away indoor with stock antenna, very nice. so more to come EdWRKU609W4EDS brasda91 and NCRick 2 Quote
Lscott Posted March 8, 2021 Report Posted March 8, 2021 The screen shots of the programming software looks a whole like the Kenwood stuff I have. I had to look again at them just to be sure it wasn't. Quote
tpp517 Posted March 9, 2021 Report Posted March 9, 2021 Got a pair delivered today, charged them up and programmed using software I downloaded. Was a bit of a pain getting the program to link to a com port but once I did it was easy. Both radios put out a full 5W on my Bird 43, with no fade out and the audio is loud and crisp. Will test more in the coming days, overall very pleased. Radioboy1962 1 Quote
Lscott Posted March 10, 2021 Report Posted March 10, 2021 Got a pair delivered today, charged them up and programmed using software I downloaded. Was a bit of a pain getting the program to link to a com port but once I did it was easy. Both radios put out a full 5W on my Bird 43, with no fade out and the audio is loud and crisp. Will test more in the coming days, overall very pleased.I just heard one on the local GMRS repeater. I agree about the audio. Very crisp and clear. Nice sounding radio. Radioboy1962 and Hoppyjr 2 Quote
WRKU973 Posted March 22, 2021 Report Posted March 22, 2021 Got mine about two weeks ago and I am very impressed with it. Weighty due to the extended battery. Quite impressed by the stock antenna but will try out a few others for the fun of it. I too, had issues downloading the software. Scanned it with malwarebytes, but windows defender was blocking. Turned off Windows Defender, downloaded it, scanned it again with additional virus software - again no hits, and was good to go. Absolutely love this radio and intend to have one in each of my family's "emergency bags". Just added a gmrs radio to the bride's suv as well. Quote
ajmatson Posted March 22, 2021 Report Posted March 22, 2021 Got mine about two weeks ago and I am very impressed with it. Weighty due to the extended battery. Quite impressed by the stock antenna but will try out a few others for the fun of it. I too, had issues downloading the software. Scanned it with malwarebytes, but windows defender was blocking. Turned off Windows Defender, downloaded it, scanned it again with additional virus software - again no hits, and was good to go. Absolutely love this radio and intend to have one in each of my family's "emergency bags". Just added a gmrs radio to the bride's suv as well. Do you mind how long before you got it? I ordered from BuyTwoWayRadios.com and it said in stock mid-March but now it says Mid-April lol. Quote
brasda91 Posted April 10, 2021 Report Posted April 10, 2021 Well now BTWR says late April. This sucks. Got a license and no legal way to participate . Also have a reunion I'm going to the end of April and was looking forward to having this on the trip. Quote
WRMH343 Posted April 29, 2021 Report Posted April 29, 2021 Ordered on 4/6, still not shipped. For those that finally got theirs, when did you order? Just wondering how far back in the queue I am. Quote
Roadtrekker Posted April 29, 2021 Report Posted April 29, 2021 Ordered mine on 3/24. Still not received. I wonder what would happen if they got a huge bunch of cancellations. Quote
