WRMG216 Posted June 3, 2021 Report Posted June 3, 2021 I finally got my hands on the Wouxun KG-1000G to replace my Midland MXT 400 as my Mobile. The removable face plate is great! You can put the box under the back seat and have the faceplate up front. So far so good. Went to check my swr and power and saw I only was sending about 20 watts with an swr of 1.4. The radio has three power levels and I checked them. The display says “H” so I should be putting out closer to 50 watts. Well, looks like I have to disassemble everything and return it costing even more. I am hoping someone here van maybe shed some light on the subject. Just for info.. My Midland had an swr of 1.2 and about 35 watts. The antenna is the same. Any help would be appreciated. Thanks! Quote
SkylinesSuck Posted June 3, 2021 Report Posted June 3, 2021 What is your test equipment? Mikeam 1 Quote
mbrun Posted June 3, 2021 Report Posted June 3, 2021 I finally got my hands on the Wouxun KG-1000G to replace my Midland MXT 400 as my Mobile. The removable face plate is great! You can put the box under the back seat and have the faceplate up front. So far so good. Went to check my swr and power and saw I only was sending about 20 watts with an swr of 1.4. The radio has three power levels and I checked them. The display says “H” so I should be putting out closer to 50 watts. Well, looks like I have to disassemble everything and return it costing even more. I am hoping someone here van maybe shed some light on the subject. Just for info.. My Midland had an swr of 1.2 and about 35 watts. The antenna is the same. Any help would be appreciated. Thanks!Did you use a dummy load instead of your antenna when checking your power? If not, odds are good the power number you are getting from your SWR meter is inaccurate. I personally have experienced power readings that have been off by as much as 43% when using an antenna versus a proper dummy load.I own a 1000G also and have previously tested it with power meter and dummy load. I found the radio to be within 5% of its rated output. In fact, each of the Wouxun radios I own have tested to within 5% of their rated output when properly tested.MichaelWRHS965KE8PLM Sab02r and Mikeam 2 Quote
SkylinesSuck Posted June 3, 2021 Report Posted June 3, 2021 That's what I was getting at with my question. I'm guessing no dummy load was used. mbrun 1 Quote
WRMG216 Posted June 3, 2021 Author Report Posted June 3, 2021 Ok I think I got the answer. Let me get a hold of a dummy load and test again. I am using a MFJ-894 SWR meter for the test. The meter works as I have used it on other radios with self-test functions that show the same readings. I will get a dummy load and have a look. Thanks! mbrun 1 Quote
wjacobson Posted September 9, 2021 Report Posted September 9, 2021 I just got my license and have been researching what radio to get. This seems to be what I want. Unfortunately I have been unable to locate one, everyone is "out of stock" and the Wouxun website does not even show this as one of their products. Any help would be appreciated. Bill WRNW698 Quote
MacJack Posted September 9, 2021 Report Posted September 9, 2021 Yes it is out of stock as it a great radio... https://www.buytwowayradios.com/wouxun-kg-1000g.html This is on my wish list to purchase but I have some great GMRS repeaters that my handheld HT can reach. MacJack Quote
mbrun Posted September 9, 2021 Report Posted September 9, 2021 I just got my license and have been researching what radio to get. This seems to be what I want. Unfortunately I have been unable to locate one, everyone is "out of stock" and the Wouxun website does not even show this as one of their products. Any help would be appreciated. Bill WRNW698I recommend just placing you order if that is the radio you want. They come back in stock frequently but get snatched up quickly. The only place to buy that model is still BTWR. Not sure how long they have an exclusive on that model.BTW, I own that radio for use in my home and do like it.MichaelWRHS965KE8PLM Mikeam 1 Quote
wjacobson Posted September 14, 2021 Report Posted September 14, 2021 Thanks all, I found one in stock and it works great! Quote
DanW Posted September 14, 2021 Report Posted September 14, 2021 50 minutes ago, wjacobson said: Thanks all, I found one in stock and it works great! How did you find it in stock? Was that at Btwr? Quote
Mikeam Posted September 15, 2021 Report Posted September 15, 2021 I have had one for a while and you wont be sorry, take your time and read the manual over and over until your comfortable with making personal changes!! Quote
DanW Posted September 15, 2021 Report Posted September 15, 2021 I ordered one from btwr and it is backordered. Does anyone know how long it usually takes for them to get them in stock? I've got a trip in 3 weeks and will have to cancel and order a different radio if it doesn't arrive in time to properly install it. Quote
mbrun Posted September 16, 2021 Report Posted September 16, 2021 I ordered one from btwr and it is backordered. Does anyone know how long it usually takes for them to get them in stock? I've got a trip in 3 weeks and will have to cancel and order a different radio if it doesn't arrive in time to properly install it.I recommend giving BTWR a call. They should be able to give you a pretty good idea where you stand in the queue.MichaelWRHS965KE8PLM DanW and Mikeam 2 Quote
DanW Posted September 16, 2021 Report Posted September 16, 2021 12 hours ago, mbrun said: I recommend giving BTWR a call. They should be able to give you a pretty good idea where you stand in the queue. Michael WRHS965 KE8PLM I was able to reach them in a chat today. They said they expect a shipment before the end of September and anticipate my order will be filled soon. Thanks! mbrun and Mikeam 2 Quote
DanW Posted September 21, 2021 Report Posted September 21, 2021 I received the radio yesterday! Hopefully, I can decide the mounting arrangement in my Jeep and get it up and running this weekend. Mikeam 1 Quote
mbrun Posted September 21, 2021 Report Posted September 21, 2021 I received the radio yesterday! Hopefully, I can decide the mounting arrangement in my Jeep and get it up and running this weekend.Great news. Sent from my iPhone using Tapatalk Quote
Mikeam Posted September 21, 2021 Report Posted September 21, 2021 5 hours ago, DanW said: I received the radio yesterday! Hopefully, I can decide the mounting arrangement in my Jeep and get it up and running this weekend. You will like it read and reread the instructions they are actually accurate! DanW 1 Quote
Landshark Posted September 22, 2021 Report Posted September 22, 2021 In my Jeep I mounted the radio under the driver seat and the front control panel is mounted on an arm attached to the passenger grab handle DanW and Mikeam 2 Quote
phottomatt Posted November 16, 2021 Report Posted November 16, 2021 I checked the BTWR website every day for a week, always backorder so I went ahead and ordered it anyway on the 10, I got a shipping notification for it today. Don't wait till it comes in, if you really want one just order it. Quote
DanW Posted November 18, 2021 Report Posted November 18, 2021 Anyone know if the screen backlight can be dimmed? It's just too bright for my liking at night. I've gone through the manual many times and cannot find anything about adjusting it. Quote
phottomatt Posted November 18, 2021 Report Posted November 18, 2021 12 minutes ago, DanW said: Anyone know if the screen backlight can be dimmed? It's just too bright for my liking at night. I've gone through the manual many times and cannot find anything about adjusting it. Just got mine today, I'll take a look and see if I can find something tomorrow. DanW 1 Quote
phottomatt Posted November 18, 2021 Report Posted November 18, 2021 14 hours ago, DanW said: Anyone know if the screen backlight can be dimmed? It's just too bright for my liking at night. I've gone through the manual many times and cannot find anything about adjusting it. Man, I can't find anything about brightness either, only thing I found was color, maybe try a different color that is easier on your eyes. DanW 1 Quote
DanW Posted November 19, 2021 Report Posted November 19, 2021 8 hours ago, phottomatt said: Man, I can't find anything about brightness either, only thing I found was color, maybe try a different color that is easier on your eyes. I didn't even see color. What is it on the menu? That'd be great if we can change the color! Quote
phottomatt Posted November 19, 2021 Report Posted November 19, 2021 3 hours ago, DanW said: I didn't even see color. What is it on the menu? That'd be great if we can change the color! I think this should do it, but I don't have mine hooked up yet so I can't confirm. Quote
mbrun Posted November 19, 2021 Report Posted November 19, 2021 These color settings do not affect the screen color like they do on the 805. They are truly just affecting the color of the single front panel LED that is located next to the channel indicator. If I understood correctly, the OP wants to tone down the screen brightness at night.MichaelWRHS965KE8PLM Quote
