Well, it seems that my Motorola XPR7550e also has cold solder joints (in fact 177 radios all from the same batch) near the top of the board. Dreaded issue with many series of radios, with wave soldering being used in production, the top of the board (where the antenna, channel selector, and volume/on/off knob are located) gets the cooler solder joints that fail over time.
Or, as I put it.....Motorola Planned Obsolescence. Often times, Motorola (and other brands/model) radios end up in auction sites as they have intermittent issues related to their antenna connectors, power and volume settings (radios get bumped "Off" when the potentiometer begins to fail), or channel select issues when worn on the belt and the knobs are rubbed.
This can often be cold solder joints from manufacture. This is not limited to Motorola (I have seen this with Kenwood as well 5100/5300 series handhelds). The fix is to re-solder the connections if the pots or antenna connector is just loose, to replacement of potentiometers if volume/on/off or channel select is too loose.
3D printing also came in handy as shields can also prevent torque on the top knobs and antenna connection, preventing wear on the circuit board connections that may be prone to poor soldering during manufacture.
As for Motorola XPR7550e radios, Motorola has repaired them under warranty, or via flat-rate repair if out of warranty.....but will only support them for another three more years (the model was discontinued and replaced by the Motorola R7 series radio), you often get five years of production and five additional years of support. For those buying second hand, buyer beware, or use for negotiation of price.
Anyone else experience this with their radios (any manufacture), if so, what was the fix?
PACNWComms
22 answers to this question
