marcspaz Posted May 18, 2019 Report Posted May 18, 2019 Hey folks! I know I said I was going to wait a few days... possibly a week... before my GMRS-50X1 features review, but I spent hours using this radio today and I had a great time. I figured I would just go ahead and get it out there. For the features review, I am going to start with the Cons this time. Since the quasi-tech review ended with the focus on the negatives, I would like to end this review with a positive vibe. Please keep in mind, this is purely opinion based after using the radio. There are tons of features... I am only going to cover what I believe would be the most common/popular to use among most people. Cons -1.) While talking simplex to a station that is closer than 2 miles, I had to use low power, NFM and turn the mic gain down to 1. If not, the person I was talking to complained about audio clipping and audible popping sounds. After 2 miles, I could turn the mic gain back up and use WB FM. 2.) The display is going to be both in the Pros and Cons section. As some are aware, I daily drive a Jeep Wrangler. For at least 50% of the year, my Jeep has no roof and no doors. That fact brought out a big drawback for me. The display has no means of adjusting the brightness. Regardless of what I did, while the sun was out and the roof and doors were off, the display was 100% washed out. I literally could not tell the radio was on by looking at the display. At first, I put the soft top on, and the display was still heavily washed out, but was usable. I had to put on my top and my doors with 20% light transmission tint on the windows, before the display was good to use. Another drawback for the display is, there is a lot of very useful information in a tiny little spot. It takes a bit of focus to look at the display and get a feel for exactly what is going on. This is not good if you are driving and want to make a quick change. I found that I had to pull over to be safe while making minor adjustments. 2.) They advertise that it has NOAA radio built-in, but it really doesn't. The VFO covers a frequency spectrum that includes those frequencies. Not a big deal, but it is up to you to manually tune to those channels and save them to memory. 3.) You can't add new GMRS saved channels that are capable of transmitting. On my iCom, I have multiple saved channels for channel 15, for example. One with no DPL, one with tone coding and one with digital coding. Depending on who I am with or the group I am talking with, I need to use different values. With the BTech radio, I will have to manually change it every time. I am assuming this is so they could get FCC type approval. 4.) You can't transmit in VFO mode, at all, not even on GMRS frequencies. This was probably needed for FCC type approval. Still a drag that you can't manually dial to a GMRS frequency and use it. 5.) There are a lot of unneeded features and unusable functions that are locked out. Seems pointless to even have them because they will likely add a lot of confusion to new operators. Examples are Remote Stun which remotely disables transmitting and Remote Kill remotely disables transmit and receive. These are typically repeater management features that a typical GMRS mobile user just doesn't need. While the aforementioned features are present and function, there are a ton of other repeater related functions that are still in the menu, but you can't change them. It almost seems like they took a shortcut and used UV-50Xx software and just tweaked it for this radio. Pros -1.) Range.... My son and I ran a field test today; both simplex and repeater use. Anyone who has read my quasi-technical opinion review, knows I was less than impress with what I saw. That said, going from my BTech mobile to my son's HT inside his car, we easily talked 5.5 miles in rough terrain and while I was on the blind side of a hill, 100 feet+ below the top of a hill and there were lots of trees, buildings, etc. between us. I was pretty impressed that we got that range with my son's radio "inside" his car, while driving, and he was using an HT that has a maximum power of 8 watts. That was more than twice as far as the results we had with another brand mobile I own... using the same HT. Once we were out of simplex range, we switched to a local repeater. I am 22 miles from the repeater as the crow flies. I was using low power (2.5w) WB FM. My son was 19 miles away from the repeater using the HT, on full power and WB FM. My son gave me the the same signal report as others. He said there was some noise on low power, but when I switched to medium power (18w) I was full quite and great audio quality. Given the RF signal quality I observed with analyzing tools, I am seriously shocked. 2.) While the display washed out very easily by the sun light, the display colors are extremely flexible, allowing the user to adjust the color contrast, making it easier to read as well as using font color to further segment the many items displayed on the screen. 3.) The owners manual states that the device has a 50% duty cycle. There is no power level specified, but I assume in low power. My son and I talked for more than 30 minutes, with most of my transmit time being at medium power and at about 35-40% duty cycle. During our conversation my son reported that there was no noticeable deviation of carrier or modulation. My receive quality stayed great the whole time as well. 4.) The radio only draws 3.5 amps while using the radio at full power, with the cooling fan running. The radio came with large gauge power wires. They are not labeled, but they measure about 2mm. They are likely 14 gauge, rated for 15 amps. That's a plus, as you are less likely to have voltage drop over the length of the wire and the fuse will pop long before the wires become a fire risk. 5.) While its not very useful for most cars/trucks, it does receive commercial FM Radio. This is great feature for vehicles that don't have a radio, such as ATV's, older work trucks, construction equipment, etc. 6.) You are able to monitor up to 4 frequencies and/or channels at once. The ability to mix monitoring VFO and Memory channels can be pretty handy. 7.) A cool feature that this radio has is, you can sync the displays in pairs of two. This can be a pretty neat feature. I set display A (top left) and display B (bottom left) to be in sync. This means when I change the channel on Channel A, channel B changes as well. The inverse also occurs. This allows a user to do things like have the channel Name displayed and the frequency displayed at the same time. You don't have to guess where you are if you are using channel names. 8.) This unit displays the DPL code and method on the screen. This is awesome, because you don't have to guess if your DPL is set or to what value. Its right there to read. 9.) This unit has a feature that is getting more popular; DPL scanning. If there is a group that is using DPL and you want to be part of the conversation, you can have the radio scan tone squelch and DCS values while the other station is transmitting and the radio will detect the value that the group is using. Indifferent -Something that is not really a pro or con... since we can only transmit on the hard-coded GMRS channels, 225 additional memory channels does not make a lot of sense to me. I'm sure some will love it. With the exception of programming the WX channels, I likely wont use any more than that. Summary -Quasi-tech review aside, if you are willing to tolerate some of the technology shortcomings I noticed in my radio (noted in another thread), for a low cost radio, this can be a lot of fun to play with. Sadly, the display washout is a deal-breaker for me, personally. However, I think I am in the minority there. In short, I am not going to recommend or condemn the radio. It's not for me, even with all the cool features. That said, I leave it to you to use my two threads as a tool to make an informed decision. I'm just 1 guy with one radio... but there it is. Thanks,Spaz BoxCar, SteveC7010, andygeekboy and 7 others 10 Quote
Elkhunter521 Posted May 18, 2019 Report Posted May 18, 2019 Hey Spaz, Outstanding review. Thank you for the work. Check out the manuals for the GMRS-50X1 and the UV-50X2. They used a corrected version for the new radio. Probably just like the firmware. Thanks again,Keith T marcspaz 1 Quote
PRadio Posted May 18, 2019 Report Posted May 18, 2019 Summary -Quasi-tech review aside, if you are willing to tolerate some of the technology shortcomings I noticed in my radio (noted in another thread), for a low cost radio, this can be a lot of fun to play with. Sadly, the display washout is a deal-breaker for me, personally. However, I think I am in the minority there. In short, I am not going to recommend or condemn the radio. It's not for me, even with all the cool features. That said, I leave it to you to use my two threads as a tool to make an informed decision. I'm just 1 guy with one radio... but there it is. Thanks,Spaz Thanks for the review. Since it's not for you, I'll give you 100 bucks for it. marcspaz 1 Quote
marcspaz Posted May 18, 2019 Author Report Posted May 18, 2019 Thanks for the review. Since it's not for you, I'll give you 100 bucks for it. I'll send you a PM. PRadio 1 Quote
WRAE660 Posted May 20, 2019 Report Posted May 20, 2019 Good review, lots of real-world examples of what I will use the radio for. Thanks for your time and effort! marcspaz 1 Quote
intermod Posted May 21, 2019 Report Posted May 21, 2019 Mr Spaz: Does the radio "scan" for DCS or CTCSS codes (by stepping through each one) or does it actually read/decode them? Sometimes the transmissions I am trying to decode are very short, so stepping through them would be a painful process. Also - will the radio support a transmit DCS code and an analog receive code? Some repeaters use this combination to better secure access. intermod Quote
marcspaz Posted May 21, 2019 Author Report Posted May 21, 2019 Mr Spaz: Does the radio "scan" for DCS or CTCSS codes (by stepping through each one) or does it actually read/decode them? Sometimes the transmissions I am trying to decode are very short, so stepping through them would be a painful process. Also - will the radio support a transmit DCS code and an analog receive code? Some repeaters use this combination to better secure access. intermod The radio will scan through the tone codes and digital codes while receiving, to find a match. The digital code scan is almost instant, but the TSQL is a bit slower. Once you put it in DPL scan mode, it will continue to scan until the correct squelch is found. However, unless someone is transmitting for 15 to 20 seconds straight, TSQL may take a couple of transmissions before the tone is found. In my opinion, less than 30 seconds isn't bad. Yes, you can run split DPL methods on transmit and receive. Elkhunter521 and PRadio 2 Quote
Elkhunter521 Posted May 21, 2019 Report Posted May 21, 2019 Wow Spaz, Thanks again for the tech review of this radio. I wish you had done one on another popular, and infamous 40 watt GMRS before I bought one. I would love to see a side by side comparison of the two radios. Thanks again. Keith T marcspaz 1 Quote
intermod Posted May 21, 2019 Report Posted May 21, 2019 The radio will scan through the tone codes and digital codes while receiving, to find a match. The digital code scan is almost instant, but the TSQL is a bit slower. Once you put it in DPL scan mode, it will continue to scan until the correct squelch is found. However, unless someone is transmitting for 15 to 20 seconds straight, TSQL may take a couple of transmissions before the tone is found. In my opinion, less than 30 seconds isn't bad. Yes, you can run split DPL methods on transmit and receive. Thanks. With all the DSP capability today, you would think they could decode (not scan) either in under 200 milliseconds. My 1995 Zetron community repeater tone panel did this, as well as my new SDS200 Uniden scanner. The split code thing is good news. G marcspaz 1 Quote
WQPT412 Posted May 22, 2019 Report Posted May 22, 2019 Thank you for the review. Informative! marcspaz 1 Quote
coryb27 Posted June 2, 2019 Report Posted June 2, 2019 I will let these images do the talking... All tests done on Wideband 462.550, High power, 1 min on 5 min off for a total of 10 min TX time over 60 min at 14.7V. I have worse results but these will do. After the 3rd cycle the power output started to drop and the current draw increase. Not sure if poor thermal management is part of it but I am sure most of it is the junk output transistors. http://mwgmrs.com/mygmrs/50x1/1.jpghttp://mwgmrs.com/mygmrs/50x1/12.jpghttp://mwgmrs.com/mygmrs/50x1/9.jpghttp://mwgmrs.com/mygmrs/50x1/testresults.jpg marcspaz and BTombaugh 2 Quote
n4gix Posted June 2, 2019 Report Posted June 2, 2019 Man that is some dirty output. How did it ever pass certification? mcallahan 1 Quote
berkinet Posted June 2, 2019 Report Posted June 2, 2019 Indistinguishable from a wide band UHF frequency jammer. WRAE660, marcspaz and coryb27 3 Quote
marcspaz Posted June 2, 2019 Author Report Posted June 2, 2019 Man that is some dirty output. How did it ever pass certification? My guess/opinion is that someone cherry-picked a "special" radio to be tested or the results are fraudulent. Again, just my opinion. coryb27 1 Quote
coryb27 Posted June 3, 2019 Report Posted June 3, 2019 This is no different from any of the cheap Chinese radios that have come across my bench. I think its time the FCC starts doing its own testing, this goes to show the Chinese manufactures dont care and will fudge the paperwork to make this junk sellable in the US. As I have stated before none of these CCR's belong in use on GMRS as even the certified ones don't meet spec or standard. The spurs in the 900 band where strong enough to pick them up several 100 feet away on a scanner. Elkhunter521, marcspaz and gman1971 3 Quote
Elkhunter521 Posted June 3, 2019 Report Posted June 3, 2019 This just makes it more obvious that we should just buy and use radios made in the USA. Hmmmmm, gonna get quiet if we do that!! Quote
coryb27 Posted June 3, 2019 Report Posted June 3, 2019 This just makes it more obvious that we should just buy and use radios made in the USA. Hmmmmm, gonna get quiet if we do that!! I have tested Motorola, Kenwood, Icom, Midland, Macom, etc.. All of these radios are for the most part spectrally clean, the audio does not over deviate and the error rate on the transmitters is always within spec. This just goes to show you get what you pay for in electronics. kipandlee 1 Quote
marcspaz Posted June 3, 2019 Author Report Posted June 3, 2019 The spurs in the 900 bad where strong enough to pick them up several 100 feet away on a scanner. Wow! I only tested at 5 feet/meters. It didn't dawn on me to see just how far I could get. I'm really shocked... but I shouldn't be. LOL coryb27 1 Quote
berkinet Posted June 3, 2019 Report Posted June 3, 2019 This just makes it more obvious that we should just buy and use radios made in the USA. Hmmmmm, gonna get quiet if we do that!!Unfortunately, a lot of crap is made right here in the US and some quality product is manufactured overseas. Not only that, but some products sold by American companies are imported, especially at the low end of the line. But, I think Corey hit the nail on the head when he wrote......This just goes to show you get what you pay for in electronics.... and many other things in life. marcspaz, Elkhunter521, kipandlee and 1 other 4 Quote
Elkhunter521 Posted June 3, 2019 Report Posted June 3, 2019 I've asked this before. Why can't somebody make a GMRS mobile radio that is 25 to 40 watts, works like we want for $150? And is part 95 certified? 1. Clean, on frequency emissions. 2. Wide or narrow band. (Narrow band to work best with bubblepack radios.) 3. Split pl tones for tx and rx. Or just squelch. 4. Multiple channels for the same repeater channel to allow preprogramming of pl tones for a trip. This doesn't sound like rocket science. Just an observation, I do not have an amature license. At the present, I am not planning to get one. I don't know any one with an amature license in my area. Radios don't do much if you don't know any one to talk to. ljones135 and fremont 2 Quote
marcspaz Posted June 3, 2019 Author Report Posted June 3, 2019 Sounds like a gap waiting to be filled by a motivated and talented individual. Quote
Jones Posted June 3, 2019 Report Posted June 3, 2019 Just an observation, I do not have an amature license. At the present, I am not planning to get one. I don't know any one with an amature license in my area. Radios don't do much if you don't know any one to talk to. Perhaps you should contact an area ham, or the ARRL, and ask about local clubs. A quick search shows 148 licensed ham operators in ZIP code 98671 alone. There must be SOMEONE to talk with. Quote
coryb27 Posted June 4, 2019 Report Posted June 4, 2019 I've asked this before.Why can't somebody make a GMRS mobile radio that is 25 to 40 watts, works like we want for $150? And is part 95 certified? 1. Clean, on frequency emissions. 2. Wide or narrow band. (Narrow band to work best with bubblepack radios.) 3. Split pl tones for tx and rx. Or just squelch. 4. Multiple channels for the same repeater channel to allow preprogramming of pl tones for a trip. This doesn't sound like rocket science. Just an observation, I do not have an amature license. At the present, I am not planning to get one. I don't know any one with an amature license in my area. Radios don't do much if you don't know any one to talk to You are asking a lot for 150 bucks, quality components and engineering cost money. The small profit margin would require every GMRS license holder in the US to purchase several 150 dollar radios just to recover the engineering costs let alone the rest of the expense of bringing a product to market. Its simple economics and GMRS is to little of a market share to invest in. berkinet, n4gix, Logan5 and 2 others 5 Quote
berkinet Posted June 4, 2019 Report Posted June 4, 2019 ....every GMRS license holder in the US to purchase several 150 dollar radios just to recover the engineering costs let alone the rest of the expense of bringing a product to market.... Well, let's see. If every active GMRS licensee (the FCC says there are 56,338 of us) bought 1 radio at $150 ea. that would net $8.4M. Then, let's assume retailer profit is 40% (66% markup). That leave $100 per radio ($5.4M total) to the manufacturer (we won't worry about any wholesalers, etc. here). Now, I'll take a wild guess and say it would cost $200k to design a radio from scratch (I.e. not base it on any existing product) and another easy $200k to setup the manufacturing capability. That brings the manufacturer's gross income down to an even $5M. Next, let's guess each radio costs $50 to manufacture, and another $10 to box, warehouse and ship. That is a cool $2.8M and the manufacturer is now down to $2.2M. Note that if this was the only product of its type, the manufacturer's costs would be much higher. Next, in order to get 56,000 people to buy this radio you have to advertise. Easily $0.5M and throw in another $0.5M for promotion, trade shows, etc. Now we are down to $1.2M. Taxes, overhead, retirement plans, health insurance would likely add another $2M and we end up with a nice profit of $1,000,000.00 IF every single GMRS licensee actually bought one. The real number is likely to be under 10%. But, let's be generous and say it would be 25%. So, after all this work the net profit is going to be around $200,000 and would result in a totally saturated market for years to come. And, don't forget you have to either pay off your investors or the bank, or have had the cash to finance this on your own. And, THAT is why you do not have the perfect GMRS radio being sold today for $150. coryb27, Elkhunter521 and BTombaugh 3 Quote
Elkhunter521 Posted June 4, 2019 Report Posted June 4, 2019 Ahh, I knew there was a reason. I was afraid there was a logical reason. I guess i'll have to go back to when I was a kid. Two tin cans, two buttons and a tight string. pamuth, berkinet and n4gix 3 Quote
