marcspaz Posted April 28, 2023 Posted April 28, 2023 Man... I don't know why everyone raves about Ghost antennas. This one has no range. Once I'm a few yards away from the other radio, I can't hear them and they can't hear me. Weird part is, the cable is fine and the SWR is spot-on, 1:1. Picture for attention. [/TROLL] SteveShannon, Blaise, rivrrat and 10 others 1 12 Quote
SteveShannon Posted April 28, 2023 Posted April 28, 2023 2 hours ago, marcspaz said: Man... I don't know why everyone raves about Ghost antennas. This one has no range. Once I'm a few yards away from the other radio, I can't hear them and they can't hear me. Weird part is, the cable is fine and the SWR is spot-on, 1:1. Picture for attention. [/TROLL] That's great!!! It could only have been better if it said "NOTARUBICON". WRYF747, StogieVol, WRXB215 and 3 others 1 5 Quote
marcspaz Posted April 28, 2023 Author Posted April 28, 2023 7 minutes ago, Sshannon said: That's great!!! It could only have been better if it said "NOTARUBICON". I'm out of likes that is funny though!!! SteveShannon 1 Quote
SteveShannon Posted April 29, 2023 Posted April 29, 2023 (edited) Edited April 29, 2023 by Sshannon Safe from Reddit Baofeng UV5R WRQC527, marcspaz, WRYF747 and 4 others 1 6 Quote
SteveShannon Posted April 29, 2023 Posted April 29, 2023 2 hours ago, hfd376 said: It'll never get hot... Right? Good airflow! marcspaz 1 Quote
wayoverthere Posted April 30, 2023 Posted April 30, 2023 On 4/28/2023 at 1:51 PM, marcspaz said: Man... I don't know why everyone raves about Ghost antennas. This one has no range. Once I'm a few yards away from the other radio, I can't hear them and they can't hear me. Weird part is, the cable is fine and the SWR is spot-on, 1:1. Picture for attention. [/TROLL] But the real question is...will it help my uv5r not desense itself completely deaf? marcspaz 1 Quote
WRQC527 Posted May 1, 2023 Posted May 1, 2023 On 4/28/2023 at 1:51 PM, marcspaz said: I don't know why everyone raves about Ghost antennas. The problem is obvious. Those fins are horizontal. You need to turn it 90 degrees so the fins are vertically-polarized. I'll bet you double yor range. Over2U, marcspaz, SteveShannon and 1 other 2 2 Quote
marcspaz Posted May 1, 2023 Author Posted May 1, 2023 38 minutes ago, WRQC527 said: The problem is obvious. Those fins are horizontal. You need to turn it 90 degrees so the fins are vertically-polarized. I'll bet you double yor range. Nice!!! I am going to try that! Should pickup about 12dB? WRQC527 1 Quote
Lscott Posted May 1, 2023 Posted May 1, 2023 Not bad. That Ghost antenna transmits signals you can't hear without the help of a clairvoyant receiver. I can see military applications for the technology. It's right up there with fractal antennas. https://en.wikipedia.org/wiki/Fractal_antenna https://www.antenna-theory.com/antennas/fractal.php SteveShannon, marcspaz, WRQC527 and 1 other 1 3 Quote
WRQC527 Posted May 1, 2023 Posted May 1, 2023 Personally, I've always run isotropic radiators on my vehicles. AdmiralCochrane, marcspaz, BoxCar and 1 other 3 1 Quote
AdmiralCochrane Posted May 2, 2023 Posted May 2, 2023 LOL Marc, the 1:1 should have been the clue. marcspaz 1 Quote
back4more70 Posted May 2, 2023 Posted May 2, 2023 It's because you are transmitting in the microwave frequency range, and it rained. [T3A07] marcspaz 1 Quote
BoxCar Posted May 2, 2023 Posted May 2, 2023 I found another Ghost antenna for you -- Should work as well as the one you have. WRUU653 and marcspaz 1 1 Quote
wayoverthere Posted May 2, 2023 Posted May 2, 2023 10 minutes ago, BoxCar said: I found another Ghost antenna for you -- Should work as well as the one you have. Maybe I can pair 2 of them to make a dipole for double the win marcspaz and SteveShannon 2 Quote
Lscott Posted May 2, 2023 Posted May 2, 2023 42 minutes ago, wayoverthere said: Maybe I can pair 2 of them to make a dipole for double the win You can "stack" them for more power gain too. Using two will give you another 3db. wayoverthere, WRQC527, marcspaz and 1 other 1 3 Quote
SteveShannon Posted May 2, 2023 Posted May 2, 2023 1 hour ago, wayoverthere said: Maybe I can pair 2 of them to make a dipole for double the win More like a Deadpool. marcspaz, wayoverthere and WRUU653 3 Quote
Guest Posted May 13, 2023 Posted May 13, 2023 On 4/30/2023 at 6:37 PM, WRQC527 said: The problem is obvious. Those fins are horizontal. You need to turn it 90 degrees so the fins are vertically-polarized. I'll bet you double yor range. On 4/30/2023 at 7:16 PM, marcspaz said: Nice!!! I am going to try that! Should pickup about 12dB? You also need to change the color!!! A friend painted every other fin red (start with the second from the top) and then turn 90 degrees to the front of the car. My friend gained the 12 dB you talked about PLUS an extra 7.256 dB for the alternating colors ... ! Quote
WRQC527 Posted May 16, 2023 Posted May 16, 2023 On 5/13/2023 at 3:03 PM, WRXD372 said: You also need to change the color!!! A friend painted every other fin red (start with the second from the top) and then turn 90 degrees to the front of the car. My friend gained the 12 dB you talked about PLUS an extra 7.256 dB for the alternating colors ... ! True story. I have the "square fin" version of this antenna. I connected it to my Quantar repeater over the weekend and on 20 watts (the lowest setting) I was able to get a truly impressive100 yards. SteveShannon, marcspaz and WRUU653 3 Quote
BoxCar Posted May 16, 2023 Posted May 16, 2023 12 hours ago, WRQC527 said: True story. I have the "square fin" version of this antenna. I connected it to my Quantar repeater over the weekend and on 20 watts (the lowest setting) I was able to get a truly impressive100 yards. Not bad for Bluetooth. Oh, wait, you were on GMRS weren't you? WRUU653 and SteveShannon 2 Quote
WRQC527 Posted May 16, 2023 Posted May 16, 2023 5 hours ago, BoxCar said: Not bad for Bluetooth. Oh, wait, you were on GMRS weren't you? Lol 2 meters actually, which means the antenna was a little short. I could have got at least 50 yards further on GMRS. Maybe even to the end of the street. Line of sight of course. SteveShannon and WRUU653 2 Quote
Guest Posted May 18, 2023 Posted May 18, 2023 Saw this improvement in the parking lot at yesterday's ham-club meeting ... no fins but wings ! Quote
marcspaz Posted May 18, 2023 Author Posted May 18, 2023 11 hours ago, WRXD372 said: Saw this improvement in the parking lot at yesterday's ham-club meeting ... no fins but wings ! Please tell me that was a Jeep! That would make it even funnier! WRQC527 1 Quote
