WRUU653
    43
Everything posted by WRUU653
  1. Welcome @cavelamb ?
  2. I do not but you may want to throw the KG-UV9PX in the mix as I believe it’s an enhanced KG- UV9D. It’s one I’m considering anyway should I ever find time to get my ham license. Regardless I’ll be equally interested in the responses you get.
  3. Welcome @WRXD372 to GMRS ?
  4. Sure I agree with higher is always better but the “if” I was referring to is if it will be enough to reach the repeater OP was hearing.
  5. Thanks for putting that up here. I like his videos but had not seen this one. This product may be pricey but it sure is a clean install and that would be worth it to me. I have a question about the version that has two antenna mounts, is there any issue with having a ham antenna and a GMRS antenna so close to each other?
  6. I personally am not aware of any part 95e approved radios that would allow to make this change. I think the thought is if you are following the rules and using compliant radios it’s a non issue. The concern is then at least limited to those already stepping out of the regulations. Like painting lines for a crosswalk, if you step out you probably know it. Amateur Radio is painting their own lines within guidelines they have learned and have demonstrated by passing an exam for their license. My thoughts anyway FWIW.
  7. Just dinner now, which is probably healthier for me anyway. Looks like Lugers has been there a good long time. Reached out to people I know in Long Island about them but haven’t heard back. I think it’s going to be a steak night. 73’s
  8. I did edit but before your response. I thought you might be closer and I could go for a beer ?? Still a steak sounds good. Look forward to it. I’ll have to look into Peter Lugers. Though it’s been a while since I’ve been that far east. I am still sad that Jocko’s stopped doing breakfast after the pandemic.
  9. You coming all the way out here from Jersey? They are good steaks, the best. I’d rather you admit your mistake and I’ll buy you one. Unless you’re not really there, as it seems you are not. In which case let’s just make it a beer and call it good.
  10. Well since you asked, I understand those comments and yet you made an accusatory statement anyway. What I feel would be the appropriate response when it was pointed out that your statements were incorrect is something to the extent of “sorry, I misunderstood” or something to that effect not adding a laughing face when @WRUX266 questioned your statement. This in effect is what perpetuated the side issue as I see it. Finally you felt the need to say something here yet never even attempted once answering OP’s initial question.
  11. Have you tried sending Rich a message? Contact Us - myGMRS.com.webloc
  12. Thank you @WRUX266. Such a bold yet utterly false statement from @WRXE944, and then to laugh at your response. I guess he missed the punctuation. "Some people". I've made statements that were incorrect before but then I own it and admit when I'm wrong, not this guy.
  13. The display looks like it’s getting just over 14 volts if I’m reading it correctly. I really like this set up. I really don’t have a use for this, yet I find myself wanting to build one. It’s an illness really… ??
  14. Is that another way of saying sorry you were wrong? Whatever.
  15. Wrong. I just have those for scanning. It’s just my KG-935G Plus. You need a jump to conclusions mat.
  16. One more thing I would add. I like having the set of repeater programs for what I call travel repeaters. Having these eight repeater channels set with 141.3 on input and output I recently discovered a new repeater being set up locally that isn’t listed yet. The owner was doing signal strength testing with another and I jumped on and was able to talk with the owner, get permission as well as add some feedback from my location.
  17. I don’t think there is any wrong way, it’s just what works for you. If you’re like me you may change things more than once as you decide what you like. At the moment I have 1-22 standard GMRS, then the next eight I have for local repeaters, the next eight I have marked as Travel Repeaters set with 141.3 inputs and finally I have two sets of repeater frequencies with no tones for DIY to add out of area repeaters. After this I added local ham and MURS so I can set scan areas with one for just GMRS only and a second that includes GMRS, ham and MURS a scan area for civilian traffic so to speak. That’s just what I came up with but like I say whatever works for you is all that matters.
  18. Well I looked at the manual for your radio and oddly you are correct that it doesn’t mention having this feature. What you are describing is Tone Scan, here is a description from my KG-935 plus. It works for CTCSS and DCS as well, you have to select one first and someone must be transmitting to receive the tones. 21: TONE-SCAN] CTCSS/DCS Scanning Function: Scans the incoming signal for CTCSS or DCS tones to identify or confirm the correct tone. This function must be activated while receiving a signal. Options: 1. CTCSS/2. DCS Default: None. Choose the function and press [MENU] to activate the scan. Note: The scan will stop when the signal ends and resume from where it left off the next time the signal is received, until it identifies the correct tone. Use the [UP]/[DOWN] arrow keys to scan in a different direction.
  19. You can do it either way. First select channel you want to edit, then select menu, then scroll to TX-CTCSS (or RX-CTCSS, TX-DCS, RX-DCS depending on what you want to change) hit select and scroll to desired tone, select menu again and then exit.
  20. I agree with most of your post with this exception, 8-14 would not be permitted on a mobile regardless of wattage or antenna gain. “467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz.”
  21. No issues here, I can see it fine.
  22. You miss read that… Shaw Butte and the Mesa 725 repeater are on the same channel.
  23. Whew… I’m glad to see that, I was afraid it was “quit f*#@ing typing” ?
  24. I agree with both @gortex2 and @Sshannon, this is absolutely at the discretion of the repeater owner and you may want to take a look at ham as nets seem plenty and common place. At least they are around me.
  25. I have heard people recommend standing on one’s roof to check for signal strength and see if increasing your antenna height may help. Depending on the pitch of your roof this could be helpful or precarious or both. You may want to give it a try to see if it helps. Glad to see the mystery resolved. ?
