After posting to someone else's thread and realizing I hijacked his thread about scanning, I figured I'd start a new thread with cool "tips and tricks" that people have discovered with their new KG-1000G radios. Â Perhaps we can also use this thread as a "does anyone know how to..." for the KG-1000G. Â It will also be an interesting read for anyone considering this radio, since it will hopefully eventually contain a lot of detailed info about how specific features are implemented.
Â
I'll start with this one (cross-posted from the other thread - if someone can tell me how do delete that other post, I will be glad to do so!):
Â
Quickly adding a "privacy tone" that others are using on blister pack radios
My Jeep and I were in a parade over the weekend for a couple of WWII vets that were celebrating birthdays (97 and 100!).  The organizers were on GMRS/FRS HTs and I asked what channel they were on.  "Channel 7 with privacy channel 35" he told me.  Not knowing which brand radios they were using nor remembering off the top of my head which frequency corresponds to "privacy code 35" on most radios, I was able to use the Menu [41] "SC-CTC" option (which I've programmed to Key C) to "grab" their PL frequency and then save it to my radio on channel 7 within about 30 seconds.  Super handy if you're needing to inter-operate with people on Motorola, Midland, or Cobra radios and using "privacy channels".  Note: If you want to be able to RX and Tx with the tone, you need to also change the default setting for Menu [40] "SC-QT" from DECODER to ALL. Â
Â
Pretty neat feature that saved me the stress of having to manually look up possible tones and then program them via FPP while the parade was starting...
Sbsyncro
Â
Â
Top Posters For This Question
22
15
9
8
Popular Days
May 16
10
Jan 21
8
May 15
6
Jul 27
5
mbrun 22 posts
SkylinesSuck 15 posts
Sbsyncro 9 posts
Mikeam 8 posts
Popular Days
May 16 2021
Jan 21 2022
May 15 2021
Jul 27 2021
Popular Posts
Sbsyncro
n4gix
Tip: When mounting under the seat (or other hard to access locations), invest in another programming cable and leave it plugged in and coiled up so you can plug it in to a laptop whenever needing to r
mbrun
Nice observation.  Don’t let the SWR power reading mislead you. I have that same meter. The readings I get when using that meter with an antenna will at times appear as though less power is being pu
Posted Images
97 answers to this question
