mbrun Posted March 15, 2021 Report Posted March 15, 2021 Just testing out Tapatalk with the same pics in my original post..... And I didn't specify in my original post I'm using above the taillight mounts for both antennas. Sent from my Pixel 5 using TapatalkSuccess! MichaelWRHS965KE8PLM Sean WRMH985, SkylinesSuck and H8SPVMT 3 Quote
wqxq281 Posted March 20, 2021 Report Posted March 20, 2021 I think 5 years from now, when GMRS has supplanted AM based CB radio, we'll look back at Midland and Jeep(Jamboree) as a catalyst for the change. It's marketing genius. Jeep enthusiasts come from varied backgrounds, and they'll end up using GMRS outside of Jeep related activities. Sbsyncro, WQBI410 and H8SPVMT 3 Quote
Sbsyncro Posted March 20, 2021 Report Posted March 20, 2021 I just ordered a KG-1000G and wondering where to put it in the Jeep (JKUR). I have an amp/sub under the passenger seat, a Tuffy lockbox under the driver’s seat, and an Appollointech light switch controller above the rear view mirror so none of the traditional options will work. I also have a Sunrider top so mounting it on an overhead panel isn’t an option either.... For antenna I’m debating whether to go fender mount or on the rear most Rhino rack crossbar (which I assume would be superior) using a folding mount of some sort (or an antenna with folding base). Sent from my iPhone using Tapatalk Quote
kfblackz28 Posted March 20, 2021 Report Posted March 20, 2021 Just testing out Tapatalk with the same pics in my original post..... And I didn't specify in my original post I'm using above the taillight mounts for both antennas. Sent from my Pixel 5 using Tapatalkwhat brand and where did you get the tail light mounts? TJ or JK? Quote
enidpd804 Posted March 20, 2021 Report Posted March 20, 2021 Excuse the mess. We are under construction. Sent from my iPhone using Tapatalk DanW 1 Quote
SkylinesSuck Posted March 20, 2021 Author Report Posted March 20, 2021 what brand and where did you get the tail light mounts? TJ or JK?I have a TJ and both sides are Teraflex mounts. They make them for both sides. Sent from my Pixel 5 using Tapatalk kfblackz28 1 Quote
Sbsyncro Posted March 21, 2021 Report Posted March 21, 2021 Here's a question with those with more radio experience than I. For typical (GMRS only) Jeep usage scenarios (10 vehicle freeway convoys, trail runs through mixed open desert or in and out of arroyos, and traversing mountain trails in the Sierras) would you rather have: 1. 1/4, 1/2, or 5/8 wave antenna (no ground plane) 2. Fender mount or center roof rack mount If I go center roof rack mount, I will use either a fold-over antenna base or a tilt-down mount like the Comet RS-660U. If I go fold-over I haven't figured out which antenna yet (or even if there is a good option). The radio will be a Wouxun KG-1000G. I don't park in a garage, so height restrictions are a non-issue. For traveling through heavy brush, I will probably get a 1/4 wave or "stubby" antenna to swap to while on that particular section of trail. overrulecaratmutt 1 Quote
axorlov Posted March 21, 2021 Report Posted March 21, 2021 If no ground plane, the answer is simple: 1/2 wave. 5/8 will work with reduced efficiency, 1/4 will also work but your SWR will be high. overrulecaratmutt 1 Quote
kfblackz28 Posted March 21, 2021 Report Posted March 21, 2021 I have a TJ and both sides are Teraflex mounts. They make them for both sides. Sent from my Pixel 5 using TapatalkThanks for the info. I need to relocate my firestik. SkylinesSuck 1 Quote
Sbsyncro Posted March 21, 2021 Report Posted March 21, 2021 If no ground plane, the answer is simple: 1/2 wave. 5/8 will work with reduced efficiency, 1/4 will also work but your SWR will be high.Any idea if the Midland 6db antenna is a 1/2 wave? It seems like the right size to be... Quote
axorlov Posted March 21, 2021 Report Posted March 21, 2021 Any idea if the Midland 6db antenna is a 1/2 wave? It seems like the right size to be...I don't have one. Judging by photos (post 29), it has two radiating elements with a phasing/loading coil between them. Upper element is probably 1/2 wave. But hard to tell. Sbsyncro 1 Quote
SkylinesSuck Posted March 21, 2021 Author Report Posted March 21, 2021 Midland says it's a 5/8 according to the website. Anybody know of a good 1/2 wave antenna? Quote
axorlov Posted March 21, 2021 Report Posted March 21, 2021 https://www.theantennafarm.com/catalog/index.php?main_page=index&cPath=191_192_196_215But I don't have personal experience with any of them. Quote
gdeemer Posted March 22, 2021 Report Posted March 22, 2021 MXT400 (will upgrade to MXT500 when released). Mounted with a JCR Off-road overhead Molle panel in my 2021 Jeep Wrangler Unlimited Rubicon. 6db antenna mounted at the bolt forward of the radio antenna. I also have a Kenwood D710GA with the antenna mounted on the opposite side (but likely moving to rear tailgate when I upgrade the Midland). Mikeam 1 Quote
Extreme Posted March 22, 2021 Report Posted March 22, 2021 Whew. Done deal. Works as advertised. Programmed for area repeaters and simplex 'wheelin' channels + ham repeaters scan.- 3 zones. Clears the seat slide & I don't ford rivers so should be good. Kenwood TK-8180 with remote kit. Sent from my Pixel 4a using Tapatalk SkylinesSuck and Mikeam 2 Quote
Extreme Posted March 22, 2021 Report Posted March 22, 2021 1/4-20 nutserts/rivnuts, 1" bolts to attach bracket to bracket. Sent from my Pixel 4a using Tapatalk Quote
SkylinesSuck Posted April 3, 2021 Author Report Posted April 3, 2021 Enjoyed probably a few to many adult beverages last night and decided to knock this out in the wee hours. Paying for it this morning, and things aren't exactly how I wanted (crooked) but the KG1000 is in. I'm glad I didn't just cut a hole and and mount the CAT5 port for the mic without checking first. That cord would have been ripping leg hairs out non stop come shorts weather. Pretty happy with the location I decided upon. Might replace my tired CB and put the mic in that location as well. Now I just need to tidy up the cables a bit. Sent from my Pixel 5 using Tapatalk Mikeam, AdmiralCochrane and SkylinesSuck 3 Quote
RIPPER238 Posted April 3, 2021 Report Posted April 3, 2021 I just installed a MXT275 with the standard antenna and the Midland 6db nmo antenna for when i off road on my 4Runner. I had to use some of my Sons old erector-set parts to mount the mic and the smaller antenna. lol I just cant fit in the garage with the 6db antenna since i have it on the mag mount dead center of the roof. So i use the small one that came with the unit for my daily driving. Mikeam 1 Quote
SkylinesSuck Posted April 3, 2021 Author Report Posted April 3, 2021 More of a general tech question, but should I be grounding the radio power at the battery or is a chassis ground sufficient? Quote
SteveC7010 Posted April 4, 2021 Report Posted April 4, 2021 More of a general tech question, but should I be grounding the radio power at the battery or is a chassis ground sufficient?Chassis! Modern vehicles have sensors linked to the PCM or BCM on the battery ground side. Use a factory grounding point on the body/chassis. There should be one or more near the battery. They’re easy to spot. SkylinesSuck 1 Quote
kfblackz28 Posted April 6, 2021 Report Posted April 6, 2021 Just completed a GMRS test between my Jeep and the significant other. We both have Midland MXT400 w/ 6db antenna mounted on her JK and my TJ.Over 40 miles from Northern Colorado into Wyoming just south of Cheyenne.My standing elevation was at 5K' and hers traveling maxed at 6.1K' with some moderate terrain signal shadowing along the way. Clear voice typically and 3 to 5 on RX. SkylinesSuck, H8SPVMT, Mikeam and 2 others 5 Quote
brasda91 Posted April 9, 2021 Report Posted April 9, 2021 Hey Skyline, does the NASA sticker represent anything particular, or just a sticker? Sean WRMH985 1 Quote
SkylinesSuck Posted April 9, 2021 Author Report Posted April 9, 2021 Hey Skyline, does the NASA sticker represent anything particular, or just a sticker?My grandfather worked for NASA. Sean WRMH985 and Mikeam 2 Quote
SkylinesSuck Posted April 10, 2021 Author Report Posted April 10, 2021 He worked at several places in the states and around the world, but most of the time he was at Plum Brook research facility west of Cleveland. If you have ever seen the movie Armageddon, the scene where they are in a giant vacuum chamber and the female astronaut asks Bear what would happen if she kicked him in the balls, that's the world's largest vacuum chamber and it's located at Plum Brook. My kids have a tent on their bed made from cloth used in some sort of rocket humidity test that was inside that chamber. AdmiralCochrane and brasda91 2 Quote
